Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Temperature of Refrig and Freezer too warm
I have a GE profile refrigerator and the temperature is getting very warm. It was making a strange noise too. Last year I had to clean the back of the vent out. I tried that today even though it wasn't that dirty and it doesn't seem to be getting any cooler.
  • 400 Answers
Sounds like your fridge may be short of refrigerant.
Posted on Mar 05, 2009
GE Profile Refrigerator getting warm
sounds like control board in back. common for ge.
Sep 14, 2012 | GE Refrigerators
Temperature is reads 73 on freezer and 34 on refrigerator But... inside all are warm Help
It may be vice versa.
You need to check and make sure that the freezer section is 34 degree. The refrigerator compartment depends on the freezer in order to maintain a temperature suitable for food storage. If it is the case, you defrost heater and thermostat may be defective.
Dec 10, 2010 | GE Profile Stainless Bottom-Freezer...
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
The freezer is not cooling and refrigerator is not remaining cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jun 25, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Temperature to warm
that is an automatic defrost problem
timer,heater or limit switch
Apr 22, 2009 | GE Profile PCF25PGW Side by Side...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
259 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
