Question about Zebra Z4M Printer
A built in network port
I bought this printer and the supplier told it will have abuilt in network port.But I did not get it and now he says I have to buy the network card seperately at an extra cost.
What I want to know is does this come with built in network port.
How do I get the network to work what all do I have to buy.
Thanks
  • 155 Answers
Zebra sells print server for its printers, but they are very expensive. Find a mini print server with a Centronics port is cheap and serves well.
Posted on Mar 09, 2009
    Genius:
  • 2,120 Answers
No it doesn't. Only the Z4M plus has it. Buying a Centronics Printer Cable is your cheapest option..
Otherwise, you are stuck with the supplier's recommendations
Posted on Mar 05, 2009
Whats 49.4c02 error?
Per HP:
49.xxxx errors are "communication errors" and can be caused by many things:Corrupted driver, corrupted firmware, corrupted print job, bad nic card (your printer has a built in network port), bad memory DIMM, bad formatter board etc etc.
Unplug the network cable, power off and then back on..........print a configuration page...........check that the printer sees the network port (if you see the IP address on the EIO page it sees it)...........if it doesn't see it you may have a bad formatter board (the network port is built in it).
If the printer works just fine while unplugged from the network, start replacing the network cable, otherwise you need to look into your network.
Oct 17, 2014 | HP LaserJet P4015N Printer
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
on Dec 06, 2009 | Computers & Internet
How to fix error 49.4C02
According to some information I found in some other forums, the best responses and fix methods all contained these steps
-- Quoting various sources---
The 49.xxxx errors are "communication errors" and can be caused by many things:Corrupted driver, corrupted firmware, corrupted print job, bad nic card (your printer has a built in network port), bad memory DIMM, bad formatter board etc etc.
If the printer works just fine while unplugged from the network, start replacing the network cable, otherwise you need to look into your network (end quotes). Best of luck in resolving, please update this message if it did solve it.
Aug 11, 2014 | HP LaserJet 3015 All-In-One Printer
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
I want connect my lexmark e260dn with ethernet cable, but is not in same network range. How to solve this problem
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
Mar 02, 2011 | Lexmark E260dn Laser Printer
I bought a used IBM Thinkpad T20 - is the wireless card built-in
This Notebook doesn't come with abuilt in wireless , so you need to get a wireless adapter for this if you want to make it work wirelessly you can get this one from Linksys WPC54G or WUSB54GC. By the way this is the complete specs of your laptop http://www.dealtime.com/xPF-IBM-ThinkPad-T20-2647-264745U
Nov 14, 2008 | IBM ThinkPad T20 2647 Notebook
Network printer
Connect one end of an ethernet cable into the ethernet port on the printer and the other one into a free port on the router. Then, using the install CD, tell it that you are attaching a printer on the network. The software should automatically detect the printer on the network and set itself up for it.
Jun 26, 2008 | Computers & Internet
Zebra Z4M Printer Logo
113 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
