Question about Plumbing
My delta kitchen faucet (2402) has little to no pressure at faucet, but sprayer works great! help!!!
    New Friend:
  • 92 Answers
More then likley the device at the end where the water comes out is clogged unscrew clean or replace
Posted on Mar 04, 2009
  • heatguy Mar 04, 2009
    more then likley the device at the end where the water comes out is clogged unscrew clean or replace
How do I secure the quick connect clamp to my main water line?
the quick connect should go to the sprayer hose and there should be two lines for the hot and cold.....??? does that help..
Jan 26, 2011 | Delta 2402 Classic Single Handle Kitchen...
Pressure surging thru Delta single handle faucet. The water flow starts and stops suddenly when the faucet is more than half way on. Same for hot and cold.
I don't know if this is your problem or not, But I had a new faucet and it did the same thing. I found little tiny pieces of polishing media stuck in side the faucet. Every time you turn on the water it comes out fast , then trickles, drove me nuts, I took it back and got another, no problem, hope this helps.
Apr 21, 2010 | Delta 2402 Classic Single Handle Kitchen...
I have a faucet/sprayer combo and the hose came off when I was using it and now I can't seem to thread it back up....what do I use/do? p.s. I don't know what brand or model...just had to pick something so...
Disconnect hose from sprayer unscrew nut on sprayer head remove washers and you will see a small c shaped clip get that apart then remove hose and thread it back on under sink and feed it back up through sink and reconnect to sprayer
Oct 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Kitchen sprayer stays running and won't shut off
From your description it sounds like the sprayer is stuck open. Replace with a new sprayer or rebuild. Higher end faucets rebuild. Lower end faucets replace. Without the Brand or Model# this is my best guess.
Be sure to rate this response and Good luck, Phil
Dec 24, 2008 | Delta 2402 Classic Single Handle Kitchen...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
  2. Remove handle.
  3. Remove top cap.
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
96 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
