Question about Acer (4432A-002) CD-RW Burner
My cd rom is not reading i think it is missing a driver
In device manager there is a yellow triangle in front of fix dvd rw gwa 4082n ata device
and when i put a cd my laptop typically shows, how do do i want to open the cd. it does not now.
I am using a gateway laptop
  • 4 more comments
  • hphrommany Mar 04, 2009
    thanks for trying, window did not reinstalled it and in fact it simply returned to the same yellow triangle after i rebooted of course i re-installed driver as you suggested.
    no error code, in explorer i dont even see the drive. although when inserting a disc it does seem to run, leaving me to believe that the hardware works but driver is missing or corrupted.
    i have been trying to do that, to find generic ones and combined with my lack of knowledge of PC's im constantly sidetrack by update drive applications, made for selling new drives. I run into thishttp://support.microsoft.com/kb/314060 ?
    thoughts? this literature seems to be the closest but yet at the same time when I do a find, it finds nothing. so lost again...
    thanks for all your help thus far, your persistence has been kind. unfortunately i can not answer your questions. i may have deleted an application, for i was cleaning my hard drive last week. also i dont have cd to reinstal.
    gees be awesome, i do recall deleting roxio and in my device manager where i see the yellow triangle it displays this
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    Normal
    0
    font-size:10.0pt;
    Normal
    0
    font-size:10.0pt;
    HL-DT-ST DVD-RW GWA 4082N ATA Device
    its on a GatewayTA1 laptop. theres no writing that is useful/model number like on the drive itself.
    Normal
    0
    font-size:10.0pt;
    how ghetto is this? on the back of my laptop there is a non 800 support number which i phoned and after I got Gina badge#bla bla bla she confirms you can NOT get drivers from them online and either i buy their recovery cd or find my original. im sure there is other solutions to this but thought you might be entertained.
    President:
  • 1,179 Answers
The yellow triangle is signifying that there is a problem with the drive. Usually it is a driver that has gotten corrupted. Try uninstalling the drive in your device manager then reboot. See if Windows reinstalls the drive automatically. 99% of the time this will fix the problem. Hope this helps & please take a moment to rate this solution. Thanks.
Posted on Mar 04, 2009
  • 6 more comments
  • Roy Lonsinger
    Roy Lonsinger Mar 04, 2009
    It could be that the drive is bad. Is there a specific error code listed?
  • Roy Lonsinger
    Rather than reinstalling the generic windows dvd driver that came with the computer try going to the drive manufacturers website and download the driver there. See if this fixes it for you.
  • Roy Lonsinger
    Ok. Did you remove any cd/dvd burning software? If not then the link you gave is not the solution for you, it is only for those who have removed software then had the problem. When the windows drivers update pops up you should have an option to cancel & install manually from a list. Use this option & insert the cd that came with the drive. This should install the manufacturers specific driver rather than generic. If you are still having trouble let me know & we'll go from there. I won't give up if you won't.
  • Roy Lonsinger
    Ok. Did you have a version of Roxio or Nero on your computer? These are the two most common cd/dvd burning titles. If not do you know the manufacturer of your drive? Should be on the front, ie. LG, Pioneer, HP, etc. If you can give me the manufacturer of the drive & model # I'll look up the driver for you & give you a direct link, if possible, to save you time.
  • Roy Lonsinger
    Ok it's the deletion of Roxio that has caused the problem. Easiest fix would be to reinstall Roxio if you still have the cd, if not you'll have to do the steps the microsoft article you sent earlier stated to edit the bad stuff from your registry. It's not as hard as you might think. Open the article in one window & while open follow the steps in order that they have given. To open your registry editor using either XP or Vista you would just type regedit in the little box at the bottom of your start menu. I don't know the specific registry keys for your device but the article from microsoft will. If you still need help after this let me know.
  • Roy Lonsinger
    Another thought is Gateway will have all your drivers on their website. All you need to do is go to the gateway website, click on the support area and then select your specific system model # & the operating system you are using. All drivers/software that originally came with your computer will be available for free download. Hope this helps.
  • Roy Lonsinger
    Roy Lonsinger Mar 05, 2009
    I'm sorry to hear this as I thought Gateway stood by their products. Even Dell hasn't gotten so cheap as to remove the drivers area for their systems from support. I'm really sorry that I wasn't able to fix your problem.
  • Roy Lonsinger
    I just looked on the gateway website. They do provide downloadable drivers. All you need to do is go here: http://support.gateway.com/support/drive... and use your serial # to access the area. This should allow you to find the driver you need. Gina badge# must have a sales quota to meet & didn't want to steer you to the free area :x Hope this helps you out.
Dvd-rom dont' t work
make sure that the dvdrw is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 06, 2011 | LG GWA-4082N DVD RW Dual Layer Burner
Laptop DVD-CD-ROM wONT WORK
the connection wire of your laptop with DVD ROM has been got tampered . nothing to worry it is just alittle problem go to any repair shop & get it repaired.
pls rate my solution
thankyou
Feb 12, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
Dvd-rw gwa-4082n wont work
tampered connection cable with DVD rom is the problem get it repaired it will take not more than 5minutes to repair.
thankyou
Feb 11, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
Jun 21, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
LG GWA-4082N DVD RW on gateway laptop with xp home edition
-go to your start menu, bottom left
-pull up the my computer option by the control panel option
-click on my computer and look for the cd/\dvd rom drive-
-right click on it and look for an option to restore all defaults
-click on restore defaults
see if this works, if not, you will need to uniinstall and reinstall the drivers but i'm hoping my solution should do the trick..
please let me know if i can be of further assistance to you..
thanks and good luck,
d
Feb 27, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Gateway laptop dvd drive promblem
ok you need to completely remove the cdrw from the pc remove all software (turn your pc off ) reboot it with out it ,then reboot it with the cdrw in it and go to add and remove hardware in your control panel and add driver when it asks and i think it will work correctally lala linda
Feb 01, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Dvd drive not showing
Just enable in device manager .....
Nov 27, 2007 | LG GWA-4082N DVD RW Dual Layer Burner
Acer (4432A-002) CD-RW Burner Logo
229 people viewed this question
Brian Sullivan
Brian Sullivan
