Question about JVC KD-AVX33 Car Video Player
I want to instal my car cd reciver.At the back of the unit there is multy color wires.Which one is the power wires and the speakers also? Thanks
  • 33 Answers
What brand is it? They are all pretty much standard and here is a link to the wiring for it.
http://www.the12volt.com/request/request2.asp
Posted on Mar 04, 2009
I install wire from the battery to the amp ground the amp then i installed the audio jack from the reciver to amp an then the speaker wire an nothin
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
Aug 27, 2009 | Performance Teknique ICBM-772 Car Audio...
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
Speaker hookup
Use the speaker wire outputs on the wiring harness on the back of the radio. The RCA outputs are for using an external amplifier, so you do not want to use them. The speaker wires should be color coded. The front speakers are normally grey and grey with a black stripe for one side, and then white and white with a black stripe for the other side (left and right sides)
The rear speakers are violet and violet with a black stripe and the other rear is green and green with a black stripe. All the solid colors are the positive speaker output and the wires with the black stripe are the negative speaker outputs.
These speaker outputs are on the same harness as the power connections to power up the radio. I believe that it has more than 10 wires on it. I am not sure what socket you speak of that is 10 pin and has speaker outputs. The speaker outputs alone are 8 wires, so the harness will have more than 10 wires. It also has the yellow wire for constant 12 volts to keep memory, the red wire to connect to 12 volts when the vehicle is on, and the black wire for the ground. Then it should also have a blue wire for use with an external amplifier to turn it on or to use for a power antenna to turn it on. You may also find several other wires on it like the orange for illumination and brown for muting the radio when a phone is in use. Those last few wires do not need to be used unless you want them for a specific purpose.
Jan 24, 2009 | Sony CDX-GT420IP CD Player
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
CDX-P1280 multi disc unit locked up
THIS UNIT HAS A SEPERATE TWO WIRE PLUG AT THE BACK OF THE CHANGER WHICH POWERS IT, MAKE SURE THERE IS 12VOLTS GETTING TO IT
Dec 02, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Jan 21, 2007 | Pioneer DEH-425 CD Changer
JVC KD-AVX33 Car Video Player Logo
44 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
