Question about Philips 17PF9945 17 in. LCD HDTV
Philips matchline III 17PF9945/37 will not display PC after bootup it shows boot screen and windows starting but will not display after windows logo show warning cannot disply in this mode, help!!! tuesdaystduio@live.com tuesdaystudio@yahoo.com thank you
4 Suggested Answers
  • 138 Answers
SOURCE: Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Posted on Aug 20, 2008
SOURCE: Hi we have a 42in philips matchline flat tv. When ...
mine is doing the same.... any solution to fix this problem?
Posted on Sep 27, 2010
SOURCE: Philips 52'' LCD HDTV. Has PC Input Issue.
Hello Terry,
I have the exact same problem that you described. I have tried 3 different HDMI cables. I connected my laptop to another LCD TV and didn't have the issue with that TV. It seems to be something related to the Phillips TV but I am still figuring this out.
Have you solved the issue with the HDMI to HDMI cable from the PC to the TV? My TV is the exact same as yours.
Greg
Posted on Feb 11, 2011
dduncan774
  • 760 Answers
SOURCE: I connected an expensive aentenna
Go into the user menu and reprogram the stations. Make sure that it is set to program digital channels only. Not analog.
Posted on May 18, 2011
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Acer laptop display goes off after some second
Try booting into safe mode. Chances are that you have set the screen resolution and refresh rate to some value that the LCD cannot handle. That is why it works until Windows takes over. Once you are in Safe Mode you can get things under control.
Jul 20, 2014 | Acer Computers & Internet
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
Hi a have to HP dc5800 minitower itgoes in windows logo few econd after i restart the hole pc agaian. Can someone help with this
So after the windows logo shows...the pc restarts? Sounds like it might be bluescreening. Could be bad memory or some other type of hardware issue. Hard to say without more detail but you may want to try booting it into safe mode but repeatidly hitting the F8 key until it gives you the bootup options DOS screen. Choose boot to safe mode and see if it does this successfully. If so...could be a corrupted application or bad third party hardware like a usb device or sound card.
Nov 19, 2009 | Computers & Internet
Sapphire HD2400 PRO 512M - Doesn't seems to be working
For windows to work, it needs the card's drivers to display properly. The bios will display, and the beginning of windows load messages will show, but then it switches to the installed display driver. Take the card out, and use the old display method, and load the drivers for the new card. Then set the screen resolution to 800x600 and the shutdown, and install the new card. The bootup should go correctly, and once the new drivers are in, then set the resolution desired.
Oct 14, 2009 | Computers & Internet
Will not boot up. Screen displays Window XP
Use your original Windows XP CD and run the recovery console when starting up the pc. Thats should repair any files which are hanging the pc at the XP logo
Oct 13, 2009 | HP vs17
My Samsung syncmaster 171v stopped working. When I bootup my PC, it can show MS Windows splash screen, then the Windows started, it displayed the "Video Mode Not Supported" error message on the...
boot up in safe mode F8 or F5 when booted up in safe mode check video settings set to 800 *600 reboot should a least start and give you chance to set properly
Jul 16, 2008 | Computers & Internet
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
XP Bootup on Compaq
if in the starting it is showing two operating system then make sure that which one is working and which one you want to remove
then boot your system with xp and right click on the my computer icon> go to properties >click on the advanced tab > then choose startup and recovery setting > there you will see defaukt operating system if it is showing two operating system then remove the OS which you dont want. Be careful to use this option.you can reduse the time limit also.
Nov 21, 2007 | Compaq Presario 5000 PC Desktop
Philips 17PF9945 17 in. LCD HDTV Logo
233 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
