Question about HP OfficeJet 6110 All-In-One InkJet Printer
Won't feed the paper in when I print. HP6110
Won't feed the paper in when I print. HP611. Tried unplugging it , using one sheet of paper 25 sheets always says the same thing "Out of Paper"
  • jeremy_keppl Mar 04, 2009
    only one.
  • Charles Stillwell
    Charles Stillwell May 11, 2010
    how many feed trays are there?sometimes there are more than one and you need to select the one that has the paper in it.some kinds of paper will only print from certain trays.
  • 27 Answers
Try turning off the printer, unload the stack of paper, and reload 20 sheets. Make sure the paper width guides are snuggly fit. Turn on printer and try again.
Posted on Mar 05, 2009
How can I get my Avery 8876 business card sheets to feed through my printer?
Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
Nov 08, 2014 | Office Equipment & Supplies
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer feeds in 2 or 3 sheets of paper at a time and then jams
Dears eveenz,
It seems that paper feed roller of your printer is broken. This part is integrated in drive assy. You need to replace drive assy of the printer in order to feed the paper properly. I plan to discuss this topic at Inkjet Printer Forum since I cannot post image more than 150 kb here. Explanation with image will make you know more easily. Please send me your mail to ijxpert@gmail.com so I can contact you as soon as I finish my post there.
Please rate me when you find this answer be useful for you
Regards,
Nov 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Paper jam error message
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Dec 28, 2007 | Canon PIXMA iP1600 Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
