Question about Copystar Office Equipment & Supplies
Not working! error code h4
  • 154 Answers
H4 means the heat rollers aren't functioning. It could be thermistor replacement. You can get fuser parts at precission roller.com if you want to fix it yourself.
Posted on Mar 04, 2009
Gree air conditiones H4 error code
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
Apr 30, 2014 | Heating & Cooling
Error code h4
The error code H4 is a fuser error code. The cause is one of the following fuser lamp, thermal fuse or the thermistor.
Jun 07, 2013 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Toshiba e-studio120, H4 error code. what it`s meen??
seems like heat roller problem.
enter code C, exposer light buttom, C and exposer light buttom , then all the indicator in the machine goes off. then enter 14 and press print buttom. Now your machine must work. If not Pls refer to technician.
Jul 08, 2009 | Toshiba e-Studio120 Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Error code:H4-00
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
Feb 16, 2008 | Office Equipment & Supplies
H4 error code
H4 codes are related to the fusing unit. Specifically a low heat condition. Follow the reset procedure below. If that doesn't work further diagnosis of the fusing unit an peripherial circuits may be warranted.
Error code reset:
Perform the following key procedure
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5320 Black and White Copier
55 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
