Question about Audiovox MP4128 MP3 Player
Hi, i have AK3223M multimedia AP and it's games are not working
Hi, i have AK3223M multimedia AP and it is working well but i cant open any game in it.
The camera, music, video is working well.
any ideas?
How can I download free 8 ball pool game to my pc?
Are you talking about the Miniclip 8 Ball Pool? This is an ap that doens't require downloading. Either add the ap via facebook or go directly to the website where you may play:
http://www.miniclip.com/8ballpool.com
Aug 25, 2016 | Facebook Apps
I have a netgear WGR14 v9 router and my xbox360 wont let me play NBA game because i have NAT is strict and i need to open NAT. I have tried everything i can read on it and nothing seems to work.......can...
Try:
Plug the AP+4 directly into your computer via Ethernet cable. This is usually a yellow cable that is provided with the AP+4. Plug on end of that cable into the computer you are setting up the AP+4 and the other end into one of the four numbered ports on that AP+4. (Note: Make sure to have your computer off. If your computer has a wireless connection to your network disable it. If you computer has a static IP be sure to set it to DHCP.)
Next, open up your web browser (we recommend using Internet Explorer or Firefox). Delete the address that is currently present in the Address Bar.
Once the address is deleted, type http://10.0.0.200 into the Address Bar.
Press Enter.
2 You will now be logged into the Status Page of the AP+4. On the left side, click the option that reads Setup Wizard.
Click on the Next button to get started on the wizard.
3 You will now be on "Choosing an Operating Mode" screen. Here you will select Ethernet Client.
Click on Next to continue.
4 The next page is "Selecting a Time Zone." You can skip this and click Next to continue.
5 This will bring up the "LAN Interface Setup" screen.
On this page, you will need to change DHCP to Client. Once that is done, click Next to continue.
6 You will now be on "Setting up Internet Connection."
WAN Access Type needs to be set to DHCP Client. Once it is set to DHCP Client, you can click Next to continue.
7 The "Configuring the Wireless Network" screen will open.
This is where you will need the SSID and Channel of your network. Change the current SSID to match the one provided by your wireless router. Also, change the Channel to match that of your router as well. Once those are changed, you can also change Wireless Operation to Client. Click Next to continue.
8 This will take you to the final page of the Setup Wizard "Setting Up Wireless Security."
Here is where you need the Encryption type and Passphrase/Network Key. Enter the Encryption to match that of your router, if applicable. If you do have encryption, you will have a Network Key or Passphrase, depending on the Encryption type. Select Passphrase if you use WPA or WPA2. Select Hex if you are using WEP. Once the Network Key or Passphrase has been entered, click Finish.
9 Power down your computer and remove the AP+4. Plug the AP+4 into the Ethernet port of your gaming console. Follow the instructions that came with your gaming console to set up your Internet connection. The AP+4 will appear to be a Wired Connection to your Gaming Console.
For a PDF version of this answer, with screenshots, click AP4_Setup_GamingConsole.pdf in the File Attachments area below.
Nov 02, 2010 | NetGear WGR614 Wireless Router
My game of gta sanandreas is saying cannot find audio card install
kya ap marko dell ka sound driver send kar sakta ho ap driver na mari mail id par send kar do ma ap ko ap ni mail send kar deta ho
E-mail:- rahul.hacker5656@gmail.com
Sep 02, 2010 | Intel ESS ES1868F Sound Card
I can not play game in my laptop.when i open the game it says can not connect to d3d device.check directx.what will i do?
Hi!
Microsoft DirectX is a software for handling multimedia task, video and game programing. You can download DirectX compatible for the operating system that you use in your laptop.
here are the list, select the file suited for your operating system, click it and save to start downloading, once finished, install it on your computer.
1. DirectX10 - windows vista sp1 & sp2
2. DirectX 9.0c - windows xp sp2
After installing the right directX for your operating system, try to play the game and direct 3d settings will work..
Please rate if this solution work...thanks..
May 27, 2010 | ASUS P5V800-MX Motherboard
POWERSOCCER.COM doesnt work for me wen the game loads the soccer field is all white and it start freezing so i cant play? WHAT DO I DO ....??? =(
What is your computers manufacturer and model? Has this game worked in the past?
Ryan Frame
Creative Energy Associates Technical Center
Aug 16, 2009 | APC Website Pros Netobjects Fusion 10 for...
Application & Games Folder Can`t Open in my Mobile-Phone.
cant open the application and game folder ...it says operation failed problem.
May 31, 2009 | Lands Phones
Unable to open resource container?
hi there, i cant be too sure if i can help
can u access the system code input section? (read up on it)
have you tried reflashing your phone? new flash is available from lg directly any (but be careful as this may void your warranty (ask first))
if still in warranty, return it :)
Dec 18, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
FILE LOST & CAN NOT OPEN
kindly i informed u that i got a problem in my mobile game and application folder cant open it so pls give solution to open easy ..
regards
deepak
Oct 28, 2008 | Sony Ericsson W200i Cellular Phone
Playstation 2
Hi isolationman,
The screws are covered up by the pads on the bottom and square hole fillers. Take a thin blade knife and pry the squares up to reveal the screws.
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
Plz help
Have got the XP Recovery disc that came with the Machinew. It is also likely the memory is not enough for heavy work such video and games.
Jun 22, 2007 | Acer TravelMate 270XV Notebook
Audiovox MP4128 MP3 Player Logo
188 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
phil
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
