I am using samsung mobile D840 i need to download my pictures from mobile to Computer and vice versa so pls help me out the free software to be downloaded
I think u cant find the sophisticated softwares pertaining to samsung in the net . So do a thing . get a bluetooth device connected to ur pc. Install the necessary drives for the bluetooth device . now switch on the bluetooth in ur phone ,,,, and transfer ur pictures via bluetooth
Install the PC suite in your PC and connect the champ mobile to computer using data cable.Now you can start copying videos from phone to computer and vice versa.
Thank You
Download first a PC Suite software in your computer. This software will let you access the system of your phone. In this software you can transfer files, videos, audios to your phone from computer and vice-versa.
You will need PC Sync Software that will allow you to connect the KG290 to your Computer through the USB Port. The PC Sync Software is supplied with the Disc provided with KG290.
To connect your LG handset to the PC all you need to do is download PC
Sync software using LG Software Updater Application. This can be
downloaded from “Products > Manual & Software.”
Click on the link below to download the PC Sync Software:
Yep. Make sure you download the full installation package for your printer. Aslso make sure you are using the right on for your opersating sysatem. The XP one doesn't work properly on Vista and vice versa.
you don't need to be the most computer literate
just to transfer pictures from your mobile to your PC or
vice-versa..all you just need are: your USB cable and your V3i.
There are a lot of ways of transferring data but this one i am going to tell is the most easiest way.
From PC to Mobile Memory Card Only (Vice-Versa) Using USB Cable 1. On your V3i, go to: -> Settings -> Connection -> USB Settings -> Default Connection -> select Memory Card(if you have one) 2.
Connect your mobile to your PC. Your PC should detect your mobile
memory card. If Pop-up window appears asking for some actions you
should take, you may cancel it or select the "Open Folder" list from
the list box. 3. If no pop-up window appears, Open your Windows Explorer or the My Computer at your Desktop. 4.
You must see your mobile memory card now from the list of icons. It
will look something like a drive letter "E" or "F". If you have a
single hard drive with no partitions, single CD or DVD drive, your hard
drive is your letter "C", your CD or "DVD" is your letter "D" and your
mobile memory card will be your letter "E".(weew! This is the reason
why I don't take a teaching career). 5. Open that drive and you will see one folder inside named "Picture". Open it. 6. Inside that folder you should see your pictures from your mobile memory card. (Unless it is empty) 7. Your pictures is now ready for transfer.
Transferring
files is easy as copy/cut-and-paste. You can transfer pictures from PC
to your mobile as easy as that and vice-versa.
If this solution is inappropriate, please notify me and i'll try to make a revision of my "lesson-plans"!
