Our ASKO model 20605 front-load washer is getting a consitent blinking 'F3'. I checked the needle trap and it had quite a few coins in it. When the washer tries to pump out water there is a clattering sound coming from the bottom right on the front of the machine. If I hold onto the needle trap plug handle, I can feel the clattering vibration right there. Can you give me any idea what could be fouled up and perhaps what to replace? Thanks, Phil Knox.
  • Phillip Knox Mar 04, 2009
    Already did that, no luck. Still makes clattering sound. Is the pump damaged or just worn out possibly?
    Is the water pump easy to reach and check for foriegn objects?
    Brigadier General:
  • 8,619 Answers
Hi!
Have you checked the drain pump filter. There would be some dirt, debris and maybe some coins stuck inside it. Try and remove it. It would be like a white plug attached above the drain pump assembly
Posted on Mar 04, 2009
  • Rylee Smith
    Rylee Smith Mar 05, 2009
    You can access the drain pump by removing the back panel and you will be able to see pump on the inner side of the hose, when you remove it check for some obstruction. Also check out for drain pump filter, the filter is behind the little door at the bottom of the front on the machine.
    Please ask for further clarifications.
    Thanks
    Rylee
  • 408 Answers
It sounds to me like you have a foreign object in the water pump.  You can take it out yourself and clean it.  Hope it helps.
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
there s a possible damaged on the bearing on the machine, better to check first on this part.
  • micromaster
    micromaster Mar 04, 2009
    F3 error is more technical and you will need a service engineer for this.
    but you may also try to > Check
    that the outlet pipe is not blocked, or that the pump vanes are not
    jammed by a button or other foreign object. Most machines have a screw
    off cover that enables you to check this.
    Genius:
  • 1,550 Answers
F3 - Pump problem
Check pump trap and clean.
  • SAM ANDERSON Mar 04, 2009
    Pump is damaged . You need to replace pump .
  • 19,396 Answers
You need to access the drain pump an clear the hose.
  • Ginko
    Ginko Mar 04, 2009
    You need to access to the drain pump, undo the drain hose and remove the objects trap in there.
    Be prepared to collect the water when you remove the hose from drain pump.
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
Coins stuck in filter and can not be removed
It sounds like a coin is trapped outside the drum but will not
deposit in the trap? What should I do?
Dec 16, 2010 | Asko W6021 Front Load Washer
I have an asko wm200 washing machine. I have an F3 error, which is stopping me from opening the washer. The washer is also still full of water. Just need to know how to get the door to open and the water...
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Jul 08, 2009 | Asko W6761 Front Load Washer
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Jun 30, 2009 | Asko W6441 Front Load Washer
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Jun 15, 2009 | Asko W6461 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
F6 CODE
F6 on an asko washer means a fault was detected with the motor. What this means 99% of the time is the brushes in the motor are worn. As long as the armature isn't damaged, (visual inspection while turning motor shaft should identify damage) you'll be fine replacing the brushes.
part # 764414, 2 required, about $40US each (better than $400US plus for a motor).
hope that helps
good luck
May 30, 2008 | Asko W6021 Front Load Washer
Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Apr 24, 2008 | Asko W6021 Front Load Washer
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
