Question about Kalinka Zenit NV Piezo Russian Night Vision Monocular
Zenit NV Piezo / IR malfunction
I have attempted to replace the battery in my IR illuminator and it still doesn't work. Can it be repaired? Can it be replaced?
Thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
Go to; www.rugift.com , they are the dealer for these russian NV. It may be that they can repair it or give you clues as to how to fix the problem.
Good luck. :)
Posted on Apr 22, 2009
I have put new batterys in my nv-100 still nothing happens,the illuminator lights up.
I sound like the Russian manufactured image intensifier tube has gone bad. This Kalinka Zenith Piezon Russian NV monocular was and is manufactured in Russia. Have tried to use piezo handle on the top of the monocular. This is suspose to eliminate the battery for operation by using you hand and finger to pull down on the handle many time to charge up some capacitor and diodes.. GB...stewbison
Aug 23, 2011 | Kalinka Zenit NV Piezo Russian Night...
I bought a Night Owl Vision Cyclops 1 monocular marked Made in Russia from a man last weekend at a flea market. It is in pristine condition and the gentleman said it worked but he hadn't used it in a...
Hello, Is there two switches on the NV monocular? If so, one is for the IR illuminator and other is for turn the scope off/on. Also, does each switch have a LED associated with it? Green for turning on the monocular and red LED when the IR illuminator is on. Now the IR switch is a momentary switch once you push on the button it turn on IR. If you release the IR button it turns off the IR..
What do you mean by green lightening storm in the view finder? Generation 1 image intensifier tubes when ignited by 15KV it will glow green in the tube. If you look through the eye pieces there will be a green glow with fluctuating intensity as bright light impact the plate in the image tube. GB...stewbison
Aug 22, 2011 | Kalinka Zenit NV CH Russian Night Vision...
I need the instruction manual. Also, what is the top red light for? Just what does it do
Hey, you got you self a Russian NV monocular. There should be two switches. One switch is to turn on/off the unit. The second switch is used to turn on the IR illuminate--which means infrared red light. To improve the night capabilities of the NV monocular. Ther are two LED's one green for on/off switch and one LED that is red for the IR illuminator.
NO-NO-NO's
When the NV monocular isn't been used, take the batteries out. The worst NO-NO's is looking through monocular during the daylight hours. The do have metal front lens cover with a small hole in the center for a few minutes of viewing during the day. Remember---Use Only During the Night---Do look at bright lights, don't let the kids play with it and make dam sure that Grandfather doesn't get his hand on it. He will be doing long range peeping at the neighbors or the lady that leaves here blinds open during the. Kid-No, Grandfathers-N0, Fathers-that up to them. If pop going some night look see. I'll make a bit his survival ratio has raised demise by 70%. stewbison
Feb 11, 2011 | Kalinka Cyclop 1-V (NZT-1M2) Wide Angle...
I have several issues that I need some assistance with: how can I set up my NV 100 to IR useage and the on-off button does not shut down right away. Some times it will other times you need to work the...
Hello, on your Night Owl Optic NV100, it same as the Kalinka Zenith NV. First, you IR switch is a montary switch. As long as your finger push the button it stay on. Release the button it goes off.
The montary green glow after shuting off you monocular NV devise is do to capacitors discharging and keep the image intensifier tube on for a few seconds. The switch on/off is a Russian computer plastic switch it could stick sometimes. See if the rubber cover over the switch can be removed with taken it apart. If the rubber cover can be removed. Then a good switch cleaner to the clean the switches (both at the same time) See if this works. stewbison
Feb 06, 2011 | Kalinka Zenit NV Piezo Russian Night...
I can't see any object in my night vision monoscope. The batteries are new.The indicator IR and ON are illuminated when switch to on.Please advice. Thank you very much. Respectfully yours, Remigio...
Hello, did you turn the Bushnell on. There two switches one for the on/off the other is for the IR and it say on as long as your finger pushs the button. Have you used during the daylight hours, looking a bright lights. If you have, the NV has gone south in one hurry.
If want come on even though the on/off switch working. If the NV devise is work there will be a green LED on the back indicating that the devise is on. stewbison
Feb 02, 2011 | Bushnell 4x50 Prowler Night Vision...
I used my zenit NV last year and but it away and when I tried to turn back on this year, all I got was a flash like it was going to start but it went black, I but in new batteries but this did not work....
Hello, I really don't think it is the image intensifier tube that has bad. The good possiblity the piezo electric capacitor has shorted out. Have tried to charge the capacitors by hand cranking the handle on top of the Kalinka NV monocular. Try first, crank the level and get the cap charged up before turn on the switch. GB....stewbison
Nov 18, 2010 | Kalinka Zenit NV Piezo Russian Night...
What kind of batteries do i use and where do the batteries go?
Hello David. David you night vision doesn't use any batteries that one installs. You have Kalinka Zenit NV monocular that is Russian manufactured but is sold by Night Vision Optics. Your night vision uses a piezo electric ignitor to charges the batteries and charge a couple capacitors.
The lever on top to the Zenit monocular is activated by squeezing the handle that is covered in a rubber type material. Just keep squeezing on the lever and in while things will start working. Best of Luck David. GB...stewbison
Nov 11, 2010 | Kalinka Zenit NV Piezo Russian Night...
I have a NV-100 Compact with illuminator should I have to hold the switch pushed in all the time I am trying to use it?
Not all the time, but if you release the button the image will fade to nothing in a minute or so. This is how it switches itself off. Don't expose it to light while it's powered up as this might damage it.
Oct 17, 2010 | Kalinka Zenit NV Piezo Russian Night...
IR Illuminator
Go to; www.rugift.com they sell these russian NV. They can probably tell you what you need to know.
Good luck. :)
Jul 31, 2008 | Kalinka Zenit NV Piezo Russian Night...
Problem with my atn 390 nv scope
Observe the IR illuminator with a digital camera and see if it if fluctuating in output brightness. If that is OK, the problem may be in the HV circuit. They are both easy to fix if the person has some experience.
Oct 30, 2007 | ATN Aries 390 Paladin Weapon Sight
Optics Logo
975 people viewed this question
Top Kalinka Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Kalinka Optic Expert? Answer questions, earn points and help others
