Question about OKIFAX 4580 Plain Paper LED Fax
Receiving and sending faxes
We cannot get our fax machine to work. OKIFAX 4580. It is connected to the same lne that we receive phone calls on and everything appears to be connected correctely. We have been working with the phone company. What could be going wrong. Should the fax machine be on a different setting. Please advise.
thanks
Mary crumplar
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Throw it away, Mary.
  • Leroy Elliott
    Do you have a DSL phone line?
  • 313 Answers
If the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Posted on Jun 30, 2009
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
OKIFAX 4580 - Comms error
Hi just a note to say first theing to check is that the phone line is connected at both ends to correct sockets and that the connector to teh fax unit is connected to the line socket and not the phone socket as this is the main cause of line errors.. Good luck you could also check to see of you need to dial 0 or 9 first before you dial your number as you ma y be on an exchange line.. also check the fax settings to see if you have set the line type correctly either pulse or tbx..
Jun 30, 2009 | OKIFAX 4580 Plain Paper LED Fax
Cannot get messages out of memory
We switch our off, wait 10 seconds, switch on & fax is printed. We don't think we have lost any faxes this way but be aware it might happen.
Jan 29, 2009 | OKIFAX 4580 Plain Paper LED Fax
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Okifax 4580 oki "change drum soon"
1st replace drum if needs to!than press select function button!counter button,new drum reset select yes than start button should reset!
Jun 17, 2008 | OKIFAX 4580 Plain Paper LED Fax
Sending and receiving faxes
Do you have an analog phone line or are you trying to run it through a PBX system? I was just having this discussion with RKS tech support. Their fax software was hanging up as soon as the connection was established and all I had available was a VOIP phone line. It took 4 tries but I found a US Robotics fax/modem that worked fine in class 2.0 mode.
Nov 10, 2007 | OKIFAX 5650 Plain Paper LED Fax
OKIFAX 4580 Plain Paper LED Fax Logo
200 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
