No tv audio from home theater speakers. - Audio Players & Recorders
  • eharvey650 Mar 04, 2009
    Thanks for for reply. The problem is my TV is a Insignia mdl is-tv040926 which only has front and rear audio inputs no outputs. So as long as I was using the cable box the signal would input through the cable box output to the home theater system speakers. May be perfect excuse to buy that flatscreen lcd.
  • 11,896 Answers
Make sure the jacks go from the output of the televison or movie player and go to input on theater receiver. Then check to make sure theater receiver is on the input setting/channel
Posted on Mar 04, 2009
  • Nate Stansfield
    Nate Stansfield Mar 05, 2009
    OH bummer! A tv with no ouputs is really rare. I also have my cable box hooked up to my tv with rca jacks and NOT the coaxil cable. The yellow jack is for video and the red and white are for sound.
    Check sound settings on cable box and home theatre system to make sure sound is set to: stereo, speakers on, and adjust any other sound options if necessary. Make sure home theatre is set on "input" or "AV" channel. If cables and settings are correct, you should have sound with picutre. Make sure you use good rca jacks as well.
    Test sound with tv and then home theatre, if tv works, then it's your home theatre system and vise versa.
I want to upgrade to a 4k tv but my home theater does not support 4k. Can i run sound only thru it?
You can run the sound to the home theater system in many cases. It depends on the home theater system and the TV. If the home theater system has a digital audio input, it is easy to connect most 4K TVs. Connect the 4K source to the HDMI or Displayport connector on the TV. Check whether the digital audio uses an optical cable or a coaxial cable. Make sure that the TV has the matching output and get the correct cable. Set the TV to use external speakers (under the Audio part of the setup on most TVs) and turn off the internal speakers.
Very few 4K TVs have analog audio output. If your home theater system only has HDMI and analog (RCA red/white) audio inputs, you will need a digital to analog audio converter and both digital and analog audio cables. The converter will look like this: https://www.amazon.com/Gefen-Digital-Adapter-Converter-GTV-DIGAUD-2-AAUD/dp/B0013LWK3A .
I hope this helps. Please add a comment with the make and model of your home theater system if you need a more specific set of details about doing this.
Nov 20, 2016 | home Audio Players & Recorders
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
I only get sound thru home theater speaker not thru tv?
Check the wires from the source, are there audio hookup from source to tv or home theater to tv? you may need to run audio cables from source to home theater and to tv.
Feb 08, 2013 | Panasonic SC-HT940 System
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
I can not get any audio from the hometheatre when turning on TV only the audio is coming out is from the regular TV speakers. However when playing a DVD or Ipod the audio is coming out from hometheatre...
hi,
connect your tvs or cable set-top box's digital audio out to the digital audio input of ur home theater. the select the corresponding input in the home theator.
or connect set -top box's to HDMI input 1 of ur home theater, and connect its HDMI out to ur tv. assign the corresponding inputs for the hdmi 1 in ur home theater.
ok
Dec 21, 2010 | LG LHB535 Theater System
Where to plug in the home theater on the tv?
If you REALLY want to plug your tv into your home theater system there should be rca (red and white) jacks on the back of the tv that say "audio out" or "speaker out" thats your tv's audio output. which is where you would plug in the TV to your home theater system.
But there's really no reason to do this and its not the most desirable way to set u a home theater. Sound doesnt come from your tv, and therefore your tv shouldnt be plugged into speaker (unless you have old school wal cable) sound comes from your cable box, DVD player, VHS, Xbox, Ps3 etc. the sound comes from your source, and these sources should be hooked up directly you your home theater reciever
Oct 01, 2009 | Dynex Televison & Video
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
292 people viewed this question
 Grubhead
Grubhead
