IT is possible that the oil is coming from a failed gasket between the intake and the motor. First re-tension the bolts IF it still leaks remove and replace the gasket. It may be necessary to put sealer around bolts as they may go through to an area where there is oil splash.
SOURCE: oil leak in a 98 plymouth breeze 2.0
I've had a 1990 Acclaim, a 1990 Shadow, and a 1998 Breeze, all have a head gasket leak. The Breeze was the only one to have oil leak and it was on the rear of the engine. I'd guess that's your problem.
SOURCE: 98 Subaru leaking oil
Oil leak will not change run temp but can cause a fire.
The smoke is the oil burning on the engine. The 1st thing you need to do is clean the oil off the engine.
Next top oil off to the full line on the dip stick.Now start the engine hold idle up to around 1600 rpm for 1 to 2 minutes keep engine run and look for the oil leak. Don't get caught in any moving parts and things will be hot so be careful. Most likely from your valve cover.
