Question about Dell 1700 Laser Printer
Dell 1700 printer will not print
The printer is running but the light on the panel indicates that paper is needed. Seems that the printer is not picking up the paper in the
tray to print.
  • r_albrecht Mar 04, 2009
    Thanks for your response.
    The problem is the rubber wheels are not catching the paper.
  • 42 Answers
Hi albrecht,
i think u might have used ur printer without paper often . unplug the printer from system and switch it off.Replug it again on the system ant switch it on and see. Even then if it is not printing uninstall the drivers for printers and reinstall again and print.
Posted on Mar 04, 2009
Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
Try this next: It will reset the printer's configuration info.
To factory reset your Dell 1700 series printer follow these steps.
  1. Turn off your printer
  2. Open the front cover (push the button on the left side)
  3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
  4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
Dec 31, 2010 | Dell 1700n Laser Printer
Dell 1700 prints a page with parameters before every print job
Probably some sort of software glitch, I'd say. First thing to try is re-installing the software with the latest version. Here's the link to download if you need it:
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
May 01, 2009 | Dell 1700n Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Dell 1700 is printing ALL black pages...
hmm..new cartridge? Check to see it's seated properly. And after replacing, go to the admin panel for the Dell printer, and check all the settings. Then, do a single test page, before doing a print run.
http://www.kauaikeepsakes.com/computerguy/
has an option for a FREE Demo of a shared screen session. Click on the Free Demo link, and maybe we can t/s that from here.
Feb 03, 2008 | Dell 1700 Laser Printer
I have a dell 1700 laser load paper lite and ont print from tray
sure..it's in the printer control panel, under paper source. Open that up, and you'l lmost likely find that it's on a default. Also, do a print test page under admin, prior to doing any print jobs.
has an option for a Free demo of a Shared Screen session.
Jan 24, 2008 | Dell 1700 Laser Printer
Dell Laser printer 1700
pickup rollers bad, you can try to clean them with rubber cleaner but it's best to have the rollers replaced.
Jan 22, 2008 | Laser 22 ppm Mono Printer
Dell 1700 Laser Printer Logo
119 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
