Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 Crooked Convergence
I have an RCA HD52W59, and the convergence is crooked. What I mean is, after I set the convergence through the onscreen menu, the blue & red are crooked across the screen. On the left side, the blue is slightly above the other two, then matches up in the middle. The red is fine on the left side of the screen, but about 1/8-1/4" below on the right side of the screen, creating a shadow effect. They all appear to line up perfectly in the middle of the screen. Help?
Thank you
Erik
  • RCA Master
  • 8,617 Answers
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Posted on Mar 06, 2009
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
Rca tv modle #hd52w59 convergence problem need to know cong.location
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Nov 01, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
Dec 17, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Can not find convergence on tv settings
Convergence settings are internal to the set on a circuit board somewhere. If you do not have a service manual for this set and some rather expensive equipment, it is unlikely you would be able to restore convergence.
Normally, convergence does not drift unless some electrolytic capacitors have aged to the point that they cannot maintain high enough voltage. This means that, even if you could find the pots that control the convergence, they would not be able to restore convergence.
The inside of a projection TV has DANGEROUS high voltages that can persist for WEEKS after the set is turned off. We are talking HEART ATTACK voltages.
You should have your set repaired by a qualified (insured) service technician.
Oct 10, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 convergence problem
Point-by-point convergence can be set by a good technician, but the controls are not accessible to the customer. also check the fuse in the power deflection board.
Jul 26, 2009 | Televison & Video
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Convergence
customer convergence is under setup in customer menu. if you do not have this you might have the "fl231 fuse problem. this set has no convergence ic.. uses a series of transistors
Nov 04, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
this set is rather difficult to converge.. sometimes almost impossible. technicians ussally have to service mode align these set.. very time consuming and one wrong button will cause even more problems... i have spent HOURS manualy converging. Techs also use a special computer interface called "chipper cheacker" we ussally charge about 100 to do this
Jun 02, 2008 | RCA HD52W59 HDTV Projection Television
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Mar 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
