Question about Yamaha RX-V1500 Receiver
Yamaha rx-v1500 no surround sound
To alot of setting changes made trying to get surround to work. need to reset reciver to factory setting and start over, how do i do this.
  • mopar360hp Mar 07, 2009
    sorry but what you gave me did not work. I do have the manuel and can not find any settings that will let the surround sound work. I have run auto setup and all the test in the unit everything sounds good thu all speakers. I dont know what to do now, any info will help
    Thanks Rich
  • mopar360hp Mar 09, 2009
    I can get the auto setup to sound the beeps thu the speakers, but if i play a dvd or watch nascar there is no sound out of the rear speakers?
    Novelist:
  • 98 Answers
Do you have the owners manual of this Receiver. If yes, then I can guide you the page numbers:
The memory backup circuits prevent the stored data from being lost even if the unit is set in the standby mode, the power cord is disconnected from the AC outlet, or the power supply is temporarily cut. However, if the power cut is more that one week , the parameter values will retun to the factory setting. If this happens, edit the parametets again.
Now you want to reset all parameters:
Use PARAM.INI ( see page 63)
First put the MEMORY GUARD to OFF position.
To go to the the above :
Make sure the OSD is displayed.
Set AMP/SOURCE/TV to AMP,
then press MENU to enter SET MENU
Reach Option mode/2
enter C) PARAM.INI
All the parameters where changes have been made from their original setting would be marked in Asterisk(*).
Make the changes required.
Hope this works for you.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
  • Sachin
    Sachin Mar 09, 2009
    In order to understand you correctly, could you reset the Receiver or not?
    If yes, then what is happening now?
    As you tell me in auto setup all the speakers are working now? What settings are you looking for in surround?
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
PS3 with this receiver.
I dont know your reciver but if it has a hdmi input plug ps3 into it and set audio on ps3 to pcm,this will give you digital surround eg multichannel,if not you must use a optical cable from ps3 to reciver and set ps3 audio to digital.
hope this helps.
CABLE GUY.
Jun 30, 2008 | JVC RX-6030V Receiver
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Shuts down after 2 seconds
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Dec 12, 2006 | Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Receiver Logo
343 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
