Question about KitchenAid KFC3300 Mini Chopper 3 Cups Food Processor
Have trouble getting it to start
When I originally read the instructions, I thought there was a safety thing that needed to be done to start it, but I don't have the instructions anymore. It's also hard to open.
  • 145 Answers
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Posted on Aug 08, 2009
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Nov 24, 2017 | KitchenAid Food Processors
Machine won't run
plz get it serviced as it is having hardware problem
Jun 26, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Difficult to tell as I could be a few things.
Safety interlock
On Off switch
Check the safety pin or whatever stops the power unless the bowl and lid are fully in place. With the blade and bowl off you can defeat the safety by inserting a pen into the hole if it has one or a teaspoon handle into the slot if it has one.
I am a chef and in a commercial kitchen, home type processors last 15 months to 2 years max.
Even if you find the problem your problem will be finding spares unless it is a top brand.
Jan 27, 2016 | Food Processors
I need just the lid. dlc-194tx. please help
There is a small plastic piece on the lids 1-196 that slides into a slot in theback of the processer and is s safety interlock. unless your new lid will fit into that it will nto work. I know because i bought the wrong lid after the exact plastic piece broke on my original and I could not get the new one to work... right now my "work around" is to put both lids on.. the newer one does have the piece but its it the wrong place and I have to hold them while I use the processor.. sorry
Jan 30, 2011 | Cuisinart DLC-1 Mini-Prep Food Processor
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
One of the major problems I have seen with food processors is the safety switch, which will not allow the motor to turn on if the bowl and top are not properly seated. The lever and/or switch sometimes wear to the point that they no longer work (easily). I'd do a bit more checking before I discarded the machine.
Oct 23, 2009 | Cuisinart Food Processors
Bravetti Chopper Model FP 105H
Not positive as to your problem, but I was just given one of these and thought it didn't work. On closer inspection, I found a little switch that needs to be depressed from the bottom side. When I pressed it with a tiny screwdriver while holding down the bar on top, the motor runs!
I just have the white top with the motor and the glass jar thing. So I'm on a search for whatever is supposed to fit between them. There's room for a seal between the two, and I imagine it has something to push the tiny button, to activate the motor (guess technically it's a safety interlock).
In case it isn't obvious where that button is, turn the motorized plastic top upside down and look at the center. There's the star drive in the middle, and four little depressions, or holes around it. One of them isn't white inside. It's the magic switch! When I push it with a screwdriver and push the power bar, the thing comes to life...
If that works it for you, then your new mission is to figure out what pushes that button and put it in the right place.
Oct 21, 2008 | Bravetti SB212H Quad Blade Food Processor
Instructions for Cuisinart DLC-054 Pasta Attachment
I have found an instruction manual for the pasta attachment DLC-054 in my parents cookbook stand. I would be happy to copy for "f star".
Jun 22, 2008 | Food Processors
I cannot get my processor to start
Food processors are notorious for having safety interlocks. If everything - and I mean everything - isn't attached in the correct sequence and clicked into place, one of the safety switches may not be engaged.
You can test it by switching back to the setup you used before to see if it will still operate. If so, then CAREFULLY review all the steps needed to use the new setup.
Mar 12, 2008 | Cuisinart DFP-14BC Custom Food Processor
KitchenAid KFC3300 Mini Chopper 3 Cups Food Processor Logo
229 people viewed this question
Top KitchenAid Food Processors Experts
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
