Question about HP DesignJet 450c InkJet Printer
Color Upgrade Kit from 450C doesn't work in 430 plotter
I have (2) plotters....one a 450C and the other a 430. The 450C is basically worn out and was giving problems (mainly feeding). The 430 plotter has been used very little. I removed the simm chip from the 450 and placed in the 430. The 430 is not recognizing that it has been upgraded to a color plotter. I have double checked and made sure the simm is in the correct slot and seated well with no luck. I'm not getting any errors...just won't recognize the upgrade? Any ideas? EEROM need resetting?
Thanks
SOURCE: 450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Posted on Jan 25, 2008
  • 10 Answers
SOURCE: HP DesignJet 450c driver for windows vista
Sirs, as you experienced very well, Windows creates a lot of problems in plotting CAD/Cutting/Engraving works. The problem is that Windows, Plotters and Applications usually don't give good drivers, up-to-date or they don't give at all for old plotters. We can offer a solution: Winline drivers On a flatbad plotter it supports a work area of up to:
Supports long page sizes on DesignJet and Vinyl Cutters (up to 200m or 660 feet).
WinLINE has been engineered by vector driver experts to drive your plotter, cutter or engraver efficiently from popular Windows applications and to create efficient HPGL files suitable for document management systems and downstream usage. And they are those recommended from [B]HP[/B], [B]Autodesk[/B] and work great with [B]Corel Draw[/B], Power Point, Micrografx Designer, EXCELL, Lotus, [B]Word [/B]
and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA You'll find all informations at [url]www.paolocasella.it[/url]
-->winline plotter drivers
and click on english flag
Posted on Feb 22, 2008
  • 53 Answers
SOURCE: 450c color problem
There is no way a plotter can simply change from a 450c to a 430, you simply have a bad color cartrige, EVEN if it seems ok. One of the color cartriges is not working, when this happens the plotter reverts to plotting black only. Check all color cartriges carefully, and check the ready light when clipping the cartrige back, it should blink at least once and up to three times indicating the cartrige is ok. If the plotter accepts all the color cartriges then load a sheet of A4 paper and do a color cartrige alignment page, you will quickly see which cartrige is faulty.
Posted on Feb 23, 2009
  • 5603 Answers
SOURCE: max file size 450c can plot ?
You should have no trouble with the unit as additional buffering will be done in your PC if necessary. These units are a one pass rather than a whole page at a time.
Posted on Feb 18, 2010
  • 547 Answers
SOURCE: I have a hp 450c plotter and it will not print.
Has this USB to Centronics cable worked in the past, but has now stopped?
The reason I ask is that there are two kinds of parallel ports, and so two kinds of USB-to-Centronics adapators. One is unidirectional, and one is bidirectional. If your plotter requires bidirectional, then it won't work properly with unidirectional.
Posted on Jun 10, 2010
Jun 10, 2010 | HP DesignJet 450c InkJet Printer
Our 450C plotter is connected via E-Net Hub and has extened memory. The "Test Printer" works. However it will not complete an Auto Cad Drawing. The ready light continues to flash but the plotter stops. any...
This could be one of a number of things. The file being sent must be smaller than the total memory of the printer. Connect the computer directly to the plotter with a parallel printer cable and see if it prints. If you are using an OS newer than XP, try using the XP 32 bit driver. If you are printing from AutoCad 14 or older, upgrade AutoCad (newer uses Windows printer drivers). If you can print OK with the parallel cable, get new external JetDirect software from the HP website.
Jan 15, 2010 | HP DesignJet 450c InkJet Printer
MY PLOTTER DOES NOT TAKE PAPER
***try to clean sensors: maybe it's dust on them.
Then if you are running latest Windows versions, you'll need a driver. Hp has dicontinued your plotter.
www.plotterdriver.it
Apr 02, 2009 | HP DesignJet 450c InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
Plotter only printing in Cyan
Check your black cartridge. Do the pump the cartridge thing with the plunger on the left of the plotter. Check all the electrical connectors on the cariage and the cartridge - clean with water -or wd40 if you are very careful and check that all the contacts, about 40 of them are clean and undamaged on each cartridge. Replace with known working cartridges. run a color test as specified in the manual -- hp has relased the manual for this printer as they no longer service this unit.
Jun 23, 2008 | HP DesignJet 450c InkJet Printer
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
Hp designjet 450c error lights
Take all cartridges out while the plotter is on,then re-insert them one by one and watch the ready light flash after each insertion.If it doesn't flash that could mean 2 things,either the cartridge is bad or the contacts on the carriage are dirty or the entire carriage needs replacing.
I tell all of my dj-4XX customers to check the spittoon assembly(on the inside,right side)for ink buildup. If it looks clogged,you can temporarily scoop the ink that solidified out,but eventually it(spittoon)will need replacing.
Hope this helps
Jan 09, 2008 | Xerox Phaser 7750DN Laser Printer
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
65 people viewed this question
Ben Johnson
