Question about Garland H283 Gas Kitchen Range
Garland H283 gas range. Right oven wont come on.
Left oven works good. Right oven pilot stays lit but burner wont light when knob is turned on. No gas smell is noticed when knob is turned on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Posted on Mar 30, 2009
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Oven wont light stove works fine
Just click this site ;
P { MARGIN: 0px } UL { MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px } OL { MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px } http://www.repairclinic.com/0088_13_1.asp
Regards;
Don't forget to rate:
Jul 07, 2009 | Garland H283 Gas Kitchen Range
Can't find the oven pilot on an old Gaffers and Sattler "Energy Saver Range with Uni Burners"
With the help from your site I was able to hold a match under the bar under the oven shelf toward the back and light the pilot. I am SO grateful. I hadn't been able to see it but just held a match toward the back, and it lit.
Feb 27, 2009 | Garland H283 Gas Kitchen Range
I have a Garland Stove and Oven. The oven is not working right.
Hi there, most of the newer unit parts are available still, but not seeing it makes it hard to guarantee. I would advise calling a Factory Authorized Servicer in your area, having a problem with gas entering the oven, and not igniting is a serious problem, and it sounds like the pilot is lit in the oven, but could be malfunctioning.
Here is the telephone for Garland: Tel: 1.800.424.2411.
They can recommend someone in your area, or check your local phone book, for Restaurant repair companies, and contact them.
Hope that helps, and thank you.
Feb 04, 2009 | Garland H283 Gas Kitchen Range
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Gas meter was changed upon relighting,top burners pilots are on but oven not
under each (the) oven behind a panel, is a red button it may be a different color from time. this has to be pushed and held while the pilot light under the oven floor is lit with a match. it has to be held to allow enough heat to activate the thermocouple, which will keep the pilot on. if this does not work there may be an additional problem
Apr 10, 2008 | Garland H283 Gas Kitchen Range
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
539 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
