Question about Intel Desktop Board D850MD Motherboard
Configure power and reset switch
I need to configure the power and the reset switch, and the front leds in my D850MD motherboard and I don´t find the configuration in the manual.
Can you help me ?
Thanks.
Hilton.
  • 75 Answers
Hi,i have located an online manual.hope this will help.look for a picture of the board sometimes the values are marked .
http://www.intel.com/support/motherboards/desktop/d850md/
Posted on Mar 04, 2009
Need pin configuration for asus it8 712f-a
You just named off one of the CHIPSETS on the motherboard.
An ITE IT8712f-a,
http://ixbtlabs.com/articles2/mainboard/nv41-2-a8n-sli.html
"The ITE IT8712F-A chip is used to monitor: CPU and memory voltage, +3.3 and +12 V; rpm of two fans; CPU temperature (by the built-in CPU sensor) and motherboard temperature (by the on-board sensor)"
http://www.alibaba.com/product-gs/327586872/ITE_IT8712F_A_motherboard_chip_video.html
Now what is the motherboard manufacturer name (Asus?), and model number?
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
(Power On switch, Power On LED, HarDDrive LED, Reset switch)
Do you need a Front Panel header pinout?
Post back in a Comment.
Regards,
joecoolvette
Feb 13, 2013 | ASUS A7V400-MX Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
HOW TO INSTALL MOTHER BOARD
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
  • TIPS AND WARNINGS
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    Configuring motherboard powerswitch leds reset
    u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
    Jan 06, 2010 | Dell Dimension 2350 PC Desktop
    How to configure the front panel
    If you're talking software then you will need to download and/or install the Chipset drivers from your install disk or online in order to get that stuff working. If you're talking how to connect the wires into the motherboard. You have to take a look at the words on the little wires and match them with the pins on your motherboard...They are often just a USB connection. just look at the configuration of holes for the connection and match them to any open USB set of pins on the motherboard with the exact same configuration. Contact me for more info if this sounds confusing.
    ASpecialty4You.com
    Dec 21, 2009 | Intel Desktop Board D850MD Motherboard
    Front panel connections
    Hi
    those details are documented in the motherboard user manual available on this page.
    http://support.intel.com/support/motherboards/desktop/d850md/sb/cs-013275.htm
    Let me know if you need anything else.
    Thanks and good luck,
    Ekse
    Apr 27, 2009 | Intel Desktop Board D850MD Motherboard
    E-MACHINE T5248
    how old is the machine???
    what kind of hard drive??? IDE or SATA
    the newer machine do not need hard drive configuration. but not the old one.
    configure the old hard drive to "master" and the new hard drive to "Slave".
    go into BOIS and make sure both hard drives are being detected by the machine.
    Oct 19, 2008 | Computers & Internet
    Wire connections/installation
    the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
    i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
    there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
    Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
    Intel Desktop Board D850MD Motherboard Logo
    131 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
