Question about JVC GR-D295U Mini DV Digital Camcorder
JVC Model GR-DF550U in safemode
JVC Model GR-DF550U unit in safemode. I'v tried removing battery but nothing works. Tape is still in unit. Can not get it to eject.
5 Suggested Answers
JoeO700
  • 80 Answers
SOURCE: JVC Error Code 02 Safeguard Mode
Brendon, The supply side tape guide can jump out of its track and cause the mechanism to lock up. The load motor is trying to load the tape but cannot, so the load motor driver "times out" and displays the E02 error you're seeing. If you can get to it, try reseating the guide into its track, be careful not to scratch or touch the drum assy located right near the guide track. Good Luck, I hope you can resolve the problem. Joe Weibel customelectronics.org
Posted on Feb 25, 2007
JDeRuvo
  • 48 Answers
SOURCE: JVC Camcorder Model # GR-D270U
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
kala
  • 156 Answers
SOURCE: jvc GR-D250
There is any error code showing on the lcd screen?
Posted on Feb 28, 2008
SOURCE: JVC GR-DX67EK MINI DIGITAL VIDEO CAMERA
Previously, when I have experienced this problem, I have removed the battery for 24 hrs and on replacement switched the Camcorder to (M) and quickly pressed the "Menu" button. This has allowed me to scroll down the menu options to the Cam Reset option. Then I reset the camera and all is well. This has worked for the last 3 to 4 occasions, however, this time I cannot get the menu to stay on long enough to reset the camera. Any ideas?
Posted on Jul 22, 2008
mastertech48
  • 149 Answers
SOURCE: JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Posted on Sep 16, 2009
Tape won't eject on my jvc gr-d60. help please.
Remove battery
Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
Nov 16, 2014 | JVC GR Video Cameras
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
HELP ME to repair JVC GR-SXM755U
try putting tape into it may be the switch that sense tape is stuck or out of order it shud not play without tape this i s abnormal let me know if can help u further
Feb 26, 2009 | JVC GR-SXM755 Camcorder
JVC gr-d350u camcorder
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
Jul 15, 2008 | JVC GR-D350 Mini DV Digital Camcorder
JVC Comcorder in a safemode
my jvc gr-d91u is in the safe mode. it will not eject the tape or it will not record. how do i fix this problem? Please help me out kingb256@yahoo.com
Jun 26, 2008 | JVC GR-D50 Mini DV Digital Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
Apr 23, 2008 | JVC GR-SXM58 Camcorder
My Jvc Digital Video Camera GR-D371u has gone into SafeMode How would I go about getting it out of safemode i need it because i need it for my sisters wedding
JVC has some known faults with their camcorders-- and most of the solutions are outside the abilities of average users. JVC says in this instance, to remove the battery and the charger, and let the camera sit for some period of time. If the camera also has a small battery for keeping the date, remove it as well. Let is sit and then replug it in and see if this cures it.
Jan 24, 2008 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D295U Mini DV Digital Camcorder Logo
214 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
