Question about Kenmore 22422 Top Load Washer
Washer willl not spin
I can wash but it wont spin
    Scholar:
  • 56 Answers
This could be a number of things:
It could be that the lid switch is fried. If you have a meter, you can test it.
In the Whirlpool/Kenmore washers, it is common for the lid plunger to stop making contact with the lid switch. Use a pen to manually press the lid switch actuator to test this.
If your washer is a belt-drive, the spin solenoid may be fried, or may have cut wires. Give a gentle tug on the wires and see if they are intact.
It could be that the drive belt is worn out. Examine it for glazing on the sides of the belt or cracks in the power side of the belt.
If it is a direct drive washer, it may just be a worn direct drive coupler.
If you need specific instructions on replacing these parts, check out the Samurai Appliance Repair forums at http://www.applianceguru.com/
Posted on Mar 04, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Admiral washer willl not spin
hi bert check the pump for any blockages.the washer has to drain before it spins if pump is ok then fault could be the module control board the controls the motor speed hope it helps
regards
shaun
Nov 18, 2011 | Washing Machines
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My Maytag bravos wont spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Whirpool LXR9245E washer question
A blocked pump impeller is the likely suspect.
Remove the hoses and inspect for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
Machine washes but ont the spins it wont kick the clutch in
yep the clutch is going out you are lucky it will spin at all
Jan 13, 2009 | Whirlpool LSB6200KQ Top Load Washer
I have a roper washing machine that willl not drain or rinse
Check the lid switch. If it is good, replace the timer. Hope this helps!
Jan 01, 2009 | Roper RTW4100SQ Top Load Washer
LG Washer WF1081 wont' draink
try lookin i nyour manual as to how ti drain the pumpo adn remove debris from the buttontrao area , if somethings stuck in pump it willl not drain there fore not spinnig as well
Apr 09, 2008 | Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Kenmore 22422 Top Load Washer Logo
99 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
