Question about Sony KDF-E60A20 60 in. LCD HDTV
Peoples skin turn light green on screen
The peoples skins turn a light green color. The clothes and other items seem to become a greenish tint to them. If you turn the TV on and off it comes on normal for a while. The greenish colr is still there if you change channels. Any help would be appreciated. Thanks
  • Anonymous Apr 14, 2009
    cathode tubes? this tv uses a light box and there are no cathode tubes that i know of . . .the box is expensive and sony has had so many complaints they are extending warranties on these
    Sergeant:
  • 239 Answers
The cathode tubes are going out you need to replace them. there are three of them and they cost about 300 a piece. probably cheaper to replace the tv.
hope this helped
please rate well.
Posted on Mar 04, 2009
Samsung HL61A skin color is green
Need complete model #--to determie if this set uses an LED light source--if so--the red and blue LED';s have failed.
Mar 13, 2014 | Samsung HL61A750A 61" HDTV
My sanyo flat screen just went to a grey/green colour on peoples skins only. What and how can i ajust it. i've tried to adjust the colour, but it stays the same.
If you look with the model number the set MAY have a reset to try and failing that I would suspect the main board in the set which processes all information is at fault.
If using any kind of box or a receiver unplug them and plug back after a while.
Same issue when using only a DVD etc?
Jun 14, 2012 | Sanyo Televison & Video
The color is extremly messed up...peoples skin is redish and the green is like a neon color? How do I adjust the color frm the back of the tv?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 05, 2011 | Philips Magnavox 9P6034C 60" Rear...
The picture appears like a 3D picture with shadows. Usually tripled, and colors are strange. Peoples skin appears orange'ish-red, and white appears greenish...almost like holograms.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 24, 2010 | RCA P52939 52" Rear Projection Television
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony kds-60a2020 green picture tint. Can't adjust it out. Everyone looks like their skin is green etc.
Sounds like a light engine problem.Theres 3 lcd color chips in there that create the color.One of these has gone bad.You might find a light engine at discount-merchant.com
May 08, 2010 | Sony KDS-60A2020 60" HDTV
Skin tones oscillate every 5 seconds, Samsung HL-67A510 67" DLP
Go to this Website and type in your Model number they will List Parts/Prices for your TV, They also have CD Service Manual you can order!
Encompass Parts Distrubtion 1-800-638-3328
When you know Part number you can go to Ebay ,Look under Electronics ,Thats where I find alot of Parts Cheaper then what companys want for them.
You might be Looking at replacing Light Engine or the Dmd Moduel Order the CD it will help you out alot.If one side of screen starts turning Green and wrong flesh tones it is the Light Engine
Mar 21, 2010 | Samsung HL-67A510 67" DLP HDTV
Mitsubishi cs-40503 tint problem
internal codes are good, but when the is like what you post then a tech is what you need.it seems that one of the problem is the flyback transformer or the CRT cap.have a tech check you unit.
Sep 08, 2008 | Mitsubishi CS-40503 TV
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Color
The magenta section of your printhead is clogged. Or you may need to replace the printhead.
Jul 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Sony KDF-E60A20 60 in. LCD HDTV Logo
179 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
