Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Open and closing problems w/ garage door
My door will close completely & the reopen about 5 inches or more. When I try to open the door it takes several times pushing the button, but the door still has to me in motion or it wont work at all. So It's consatnly up down up down til it finally goes up. Also I know it sounds crazy but the colder it gets the worse it is
  • Glenn Mayer
    Glenn Mayer May 11, 2010
    your first problem is an adjustment to the down door travel limit ,that needs to be adjusted manually ,by you ,then you have a pressure sensitivity issue ,that also should be adjusted , please let me know what brand you have and i can help you ,different machines have different adjustment controls ,I need to know the name brand / your machine sounds like an older model because the remote sensitivity is worn out also ! please let me know Sincerely Glenn
  • 118 Answers
First adjust the down limit setting. There is two white screws on the side of the opener. The one that says down needs to be turned to the less side. One full revolution of screw adjusts approx. two inches. Turn it down until the door does not close all of the way and the slightly turn it up until the door closes all of the way with stight pressure on the door. Next there are two blue screws on the back of the opener. they should be on the five setting on both the up and down screws.
Posted on Mar 05, 2009
Garage door closes most of the way, then blinks and reopens
You can adjust the downward sensitivity by turning an adjustment on the opener
Nov 28, 2013 | Home Security
My Lift Master Formula 1 is not closing all the time. It will close about 1~2 feet the reverse and reopen. This happens using the remote and the manual button. Also, after it reopens the light blinks...
I recommend this to everyone with garage door opener problems:
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4.
Gary
Dec 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Two identical Sears doors jump about 6 to 8 inches up when opener button pressed. Periodically doors will stop at that point, need to be closed and then reopened to operate properly. Have tried adjusting...
It sounds like the door springs may be mis-adjusted. Release the doors from the opener and try raising and lowering them manually. They should not try to rise on their own.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
May 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes then reopens (does not stay shut)
On the side of your opener you will find the down limit control. Using a small screwdriver turn this control in the opposite direction of the arrow printed on the cover. May take some tweaking to get it just right.
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door reopen by itself once its closed.moment later it reopen by itself it is very unreliable.
IF IT GOES BACK UP WITHIN 5 SECONDS OF CLOSING IT IS THE DOWN LIMIT.
IF MORE THAN 30 SECONDS SEE BELOW.
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Feb 22, 2009 | Skylink Group SkyLink GT-100 Garage One...
Opener will not reverse
FIRST YOU NEED TO RESET THE CHAIN .
Unplug power
Release the door from the opener close the door manually. take the chain loose and slide the traveler down to reengage with the trolley. Plug in power, run the unit with chain off untill it completes a clockwise cycle and stops. reconnect the chain and set tension.
Adjust the chain tension.
If it still moves 6-8 inches and flashes 5 times. the problem is in the rpm sensor.
Full diagnostics are in the owners manual - FREE at
http://help.chamberlain.com/help/en-us/InstructionManuals
Oct 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
189 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
