Have a JVC42X788 model tv. TV receives signal through basic cable. On channel 29 which is the Lifetime channel the audio is in Spanish, except for the commercials which are in English. Any idea what is causing this?
  • 201 Answers
You might want to go into the audio setup or tuning setup for the tv and make sure it's on ummm, stereo, I think, but definitely make sure it's not on SAP (see if you can find SAP somewhere in the audio/tuning setup and change it). SAP stands for Secondary Audio Program.... most stations don't use this feature, but some will put out an alternate audio signal on this for whatever reason (like another language). Hope this helps!
Posted on Mar 04, 2009
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
NO AUDIO
If it is the radio you are trying to get make sure you have an antenna that is strong enough and can receive the signal. With a digital tuner it requires a strong enough signal to capture any channels.
Sep 30, 2014 | Pioneer Vsx-520-k 5.1 Channel 3d Ready...
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Mar 12, 2012 | Magnavox Televison & Video
I have a technics sa-dx930 receiver and want to hook it up directly to the tv without running it through the dvd/vcr... How would I go about setting it up and what cables go where... Sorry woman here not...
It would help to know some details about tour TV - like its make and model. Or do you mean the CABLE BOX?
And there are TWO signals to consider - audio and video. WHICH is the one you need to hook up without involving the dvd/vcr?
Let's start with basics:
1) TV's are not audio sources. They are end-units for video and its medium-fi audio.
A TV's internal audio capacity is more a convenience for stand-alone listening than a serious approach at hi-end audio. Many of us have monitors with NO audio capability.
TV-related audio and video are best VIEWED via direct video connection to the TV; and HEARD through direct digital audio connection to the receiver.
2) The one NECESSARY connection you need from the receiver to the TV is the basic VIDEO that let's the receiver communicate with you through the TV.
Jun 06, 2010 | Technics SA-DX930 Receiver
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
No audio on any channel, even in audio setup mode, no audio headp
If you have any of its sound outputs connected to a TV or tape deck do they get the signal? If so, then we know there is sound processing somewhere inside the unit but not emerging to anyplace that requires amplification.
A quick basic check would be to tune an FM station, run an RCA cable pair from the audio output for a tape deck (see the picture at the link) to an analog audio input on your TV. Select that input on the TV and you shouls hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
http://www.onkyousa.com/images/hookup/TX-SR803/detail_tapedeck.jpg
Check to make sure Multi-Channel input is not selected unless that is what you're listening to as it bypasses all other sources analog and digital EXCEPT the tape; and check any Mute or Zone Controls, too.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason. The click I asked about before... when you turn it on does it get a click about 5 seconds later. That would be the protection circuitry turning OFF to allow the amplifiers to function.
I notice it has a Tape function. Make sure it isn't selected as it assumes a tape deck or processor is attached and will only play back what would be coming FROM the tape deck or processor. On my Pioneer receiver it also disables any digital signal processing.
Sometimes when I'm watching TV with the remote on the seat someone moves and something bad happens. It's always some unfamiliar button that gets touched unintentionally. Look over the remote for things like MUTE, Multi-CH, Tape.
Apr 02, 2009 | Onkyo TX-SR803 Receiver
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Cable channels 5 and 6
not sure on this model , but check your menu and see under the setup menu if it has a band select option or tuning band. sometimes the autoprogram may pick up the wrong band. Make sure it is set correctly. I had this where it would just make some certain channels bad.
Nov 01, 2007 | Zenith A25B33W 25" TV
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Electro Med Services...
