Question about Samsung CLX 3160fn All-In-One Printer
Replace waste toner container message
We are getting a "replace waste toner container" message even though we have installed a new waste toner container. The machine is a Samsung CLX-3160 - is there anyway to clear this message??
  • Anonymous Mar 13, 2014
    replace waster toner container R5
  • Anonymous Mar 18, 2014
    Error message on my printer samsung clx-3305fw says replace or install waste toner container What does this mean?
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
  • George Shamoun
    George Shamoun Oct 25, 2013
    make sure that sensor at left is clean
  • 3 Answers
I have discover a very simple & cheap solution for this problem. The only thing you need to do is take the waste toner container and empty it, after that you clean the empty waste toner container with water and few drops of diswashing soap. You have to clean it thourougnly so that the container will be clear, shake it up until it is almost dry. Install it back and it will work.
Posted on Apr 02, 2009
  • prescon Apr 02, 2009
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
1,166 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
