2003 philips 55" hd projection,model 55pw9363/17f,chasis dptv 335 Ghosting of color away from center, lettering looks like 3-D without 3-D glasses on. multi- point converge red adjustment (in menu/manual adj.by remote) cannot synchronize crosshairs of red & yellow .complete internal cleaning,no change.TV was not moved or bumped in any way,just shut off and turned back on.
  • 10,594 Answers
It is convergence out IC failure problem and both ICs would be replaced.
Let me know if you have TV repair experience to help you more.
Posted on Mar 04, 2009
    Brigadier General:
  • 3,614 Answers
check all possible loose connections.
do unplugging the tv set and plug it on a different outlet.
let me knw
  • 13,433 Answers
Seems like the convergence IC's would need to be replaced or resoldered.
  • 19,396 Answers
You have a convergence problem.
  • Ginko
    Ginko Mar 04, 2009
    You have a convergence problem because one of the convergence ICs had blown.
    The Convergence ICs are located inside the TV, on C board.
    To test them the technician check for continuity the pico fuses at the base of the ICs.
    Open the website below to make an idea of the repair needed.
    The repair can be done at a local repair for about $200/$300
    Here the procedure
    Fixing Convergence problems in RPTV's
Philips DPTV 310, 60PP935217 We got this tv. As it was brought, they took out the front glass to transport. Question is. There are 2 glasses. Wich glass, in wich order, and which side has to be Built
The pair taped together usually are the inner and it is possible to put in backwards----should have marked this with masking tape before removal which is rarely needed to transport this set---cover with heavy quilt and face forward in a pickup etc so wind does not **** screens out.
Nov 02, 2012 | Philips Televison & Video
MY PHILIPS DPTV 335 HAS A GOOD PICTURE BUT ITS GOT A HEAVY RED TINT NO MATTER HOW MUCH I ADJUST IT.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 01, 2011 | Philips 55PW9363 55" Rear Projection...
Concave looking screen and double lettering, color aweful
you need the following comvergence repair kit it comes with the replacement ICs and resistors plus step by step instructions on how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Apr 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips hd tv
convergence i.c.s change both of them even if only one color is out. if one is bad the other is usually going to give out soon. the part # should be. stk 392-120. also check resistors around i.c.s if the open you wont be able to adjust convergence.
Mar 20, 2009 | Philips 55PP9352 55" Projection Television
Looks like 3D with out the glasses
you need the phillips dptv 305 - dptv345 chassis convergence repair kit which contains both convergence ics and all feed resistors and also free installation instructions with pictures. heres the link.
Jan 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
