Question about Uniden DXAI8580-3 5.8 GHz Trio 1-Line Cordless Phone
My uniden 5.8 ghz will only ring 2 times. I have
My uniden 5.8 ghz will only ring 2 times. I have set it to ring 6 times and the system tells me it is set for 6 times but it only rings 2 times
  • 39 Answers
Reset the base by unplugging power from back of base, press and hold the delete key while reconnecting power
Posted on Mar 18, 2009
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
How do I set the number of rings? I would like a longeer time to get to the phone - thus, more rings.
You didn't include the model number of your Uniden phone so I've given you the link for Uniden's site where you can download Uniden manuals. Send a comment with your phone model number if you need additional help.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Feb 27, 2011 | Uniden 2.4 GHz Expandable Phone System...
Hi There my uniden 5.8GHz Digital rings only twice before answer machine starts how do i extent the time of ringing? thanks
For the TRU9380, you can set the number of rings for the answering system from the handset. Press Menu/Clear and select Answ Setup. Then choose the Ring Time submenu. Move the cursor to select the number of rings (Toll Saver, 2, 4 or 6 Times). Press Select to save the setting; you will hear a confirmation tone. (Note: the answering machine must be on.) In Toll Saver, it picks up after 2 rings if you have new messages and after 4 rings, otherwise.
You can find the manual for most Uniden 5.8 GHz phones by looking up your model here: http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%205.8%20GHz%20Digital . Check here if you have a different model.
I hope this helps.
Feb 10, 2011 | Uniden Cordless Phone
How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Mar 04, 2010 | Uniden DXA15588-2 Twin Cordless Phone
Would like to increase number of rings before answering machine comes on.
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
I want to change the # of times the phone rings before voicemail picks up.
You didn't post the model of your phone, but this might work.
- Press MENU/CLOCK on the base.
- Press MENU/CLOCK repeatedly to select RING TIME.
- Press VOL/SELECT to set the number of rings at 2, 4, or 6.
- Press SET to save the setting.
If this doesn't work on your phone please post your exact model number and we'll get the specifics for it.
Dec 12, 2009 | Uniden 2.4 GHz Cordless Phone System
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Changing the amount of rings on uniden DXA15188-2
On the main base, press the menu/clock button 3 times, it will give you 3 options...2 times, 4 times, and 6 times, press set.
Jul 29, 2008 | Uniden Cordless Phone
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Uniden DXAI8580-3 5.8 GHz Trio 1-Line Cordless Phone Logo
257 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
