Question about OKI MICROLINE 590 Matrix Printer
Oki Microline 590
I have an Oki Microline 590. It will print then stop and the menu light comes on. Then it will start printing again. Then stop and so on. I know that the menu light blinking is saying that the print head is overheating. I have replaced the print head and also replaced the ribbon. And still the same results. Anymore things I can try?
  • broberts13 Mar 09, 2009
    I tried the LF/FF on power up and the printer didn't print anything. It went from one end to the other then back.
    Problem Solver:
  • 5 Answers
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Posted on Mar 05, 2009
I have a OKI Microline 590 Matrix Printer at my store. When we used to hit Utility it would print decently. The ink would be on the lighter side but it was legible. Recently someone came in to change the...
Re-install the printer ribbon. It's probably slipping or dragging on the head mechanism, and the printer synchronization control is slowing everything down to compensate.
Mar 08, 2011 | OKI MICROLINE 590 Matrix Printer
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Setting up printer for reports & checks
Press SHIFT+MENU together to enter MENU mode
press GROUP until it prints EMULATION - make sure it doesn't shows UTILITY
Best Rgds
KM Hoo
Dec 28, 2008 | OKI MICROLINE 590 Matrix Printer
OKI Microline 320 Problem...
I think you maybe using the wrong driver.Printout the menu if you are set for IBM than choose the "IBM Proprinter" driver in windows.Hope this helps.
Dezzi
Feb 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Dec 12, 2007 | OKI MICROLINE 520 Matrix Printer
How do i identify the font settings set in my printer
Your printer is designed to change font and pitch from the front panel. Just press the SEL/MENU button to take the printer offline. Then press the PRINT QUALITY button (to the right side of the panel) to make the lights switch to different fonts. Finally, press SEL/MENU to activate the changes and return the printer to online status. Be advised, these changes will not be permanent. To make a change permanent, you need to read the user's manual which I can email to you. Finally know that Windows does not pay attention to these settings, they are only goog in text applications such as DOS.
Sep 21, 2007 | OKI MICROLINE 520 Matrix Printer
How to identify current font settings
Try printing the menu like this -With power on press the "Shift" tand "Select" button, a red menu light will pop up on the touch panel ! than press the "Print" button on the touch panel-this will print out the current settings of your printer.
Good luck
Dezzi
Need Help!
Sounds like driver problems. Cant solve problems without details like what opperating system, what driver, how it the printer attached, usb, paralel, network? Will it print a test page from the driver ok?
Aug 31, 2007 | Samsung OKIDATA - OKI Microline 590...
OKI MICROLINE  590 Matrix Printer Logo
644 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
