Question about HP LaserJet 2840 Printer
I have an HP Laserjet printer and received a message about the memory being too low to print. How do I fix this?
    Sergeant:
    Champion:
  • 237 Answers
Clear the ques it is not able to print anything. The ques take up the printers memory
Thank You
John C
Posted on Mar 04, 2009
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    How do i clear the memory on hp laserjet 3015
    You clean the memory by deleting all the print jobs awaiting for printing.
    Jul 25, 2014 | HP LaserJet 3015 All-In-One Printer
    WHEN PRINTING HP LaserJet P3005n Printer A MESSAGE TONNER REFILS, BUT TONNER FULL
    Toner cartridge memory counts how many print outs passing through it, once memory sensed yield count crossed, printer will say that "low toner" , after couple of prints it will says to "replace the cartridge". If you refilled this cartridge with out replacing the memory printer will treats its old cartridge only.. Replacing the memory will solves your problem.
    Ideal memory chip...
    Sep 05, 2012 | HP LaserJet P3005n Printer
    How to solve service error 49.00 in hp laserjet 2430dtn printer
    49.XXXXX ERROR
    A critical firmware error has occurred.
    1. Press Cancel Job to clear the print job from the printer memory.
    2. Turn the printer off, and then turn the printer on again.
    3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or
    www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
    one installed on the printer and the printer can receive a firmware update,
    download the newer firmware upgrade. Not all printer models can
    receive firmware upgrades.
    4. Try printing a job from a different software program. If the job prints, go
    back to the first program and try printing a different file. If the message
    appears only with a certain software program or print job, contact the
    software vendor for assistance.
    1. After performing the actions listed in the preceding item, if the message
    persists when using different software programs and attempting specific print
    jobs, disconnect all cables that connect the printer to the network or a
    computer.
    2. Turn the printer off.
    3. Remove all memory DIMMs and thirdparty solutions from the printer.
    4. Remove all of the EIO devices from the printer.
    5. Turn the printer on.
    6. If the error message disappears, reinstall each DIMM, Compact Flash card, and EIO device one at a time, making sure to turn the printer off and then on again (booting to the Ready
    prompt) as you install each device. To replace a DIMM, see Appendix D - Printer memory and expansion in the LaserJet 2400 Series User Guide.
    7. Replace the DIMM or EIO device that caused the error message.
    8. Remember to reconnect all of the cables that connect the printer to the
    network or computer.
    9. If the error message persists, reinstall the firmware with the latest possible firmware upgrade. Go to http:www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software.
    Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update,
    download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
    10. Replace the formatter
    Feb 28, 2011 | HP LaserJet 2430dtn Printer
    I am getting "memory is low/ insufficient memory" in my hp laserjet M2727 printer. what should I do?
    The internal memory is full try a nvram.
    1. Turn the printer off
    2. Hold down the right arrow and the cancel button
    3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
    This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
    Al
    May 21, 2010 | HP LaserJet 3050 All-In-One Printer
    Describe your HP Laserjet 2430tn problem: what
    Press CANCEL JOB to clear the
    memory.
    support/lj2420, or
    Software
    . Check for the
    upgrades.
    the job prints, go back to the
    contact the software vendor
    for assistance.
    the message persists when
    specific print jobs, disconnect
    computer.
    or third-party DIMMs from the
    printer. (Do not remove the
    firmware DIMM in slot J1.)
    each DIMM and EIO device
    individually, making sure to
    on again as you install each
    see.
    error message.
    computer.
    9. If this error message persists,
    replace the firmware DIMM.
    Mar 24, 2010 | HP LaserJet 2430tn Printer
    Low memory on hp laserjet 2420 printer
    If you are printing complicated graphics, you can easily run low on memory. Order a memory upgrade from HP or google your model to find cheaper memory dimms.
    Dec 30, 2009 | HP LaserJet 2420 Printer
    Re; HP LaserJet 3030 Fax -low memory problem
    is this plugged directly into the wall by chance, or a power strip?
    Jul 28, 2008 | HP LaserJet 3030 All-In-One Printer
    Not enough memory LaserHet 6mp Printer HP
    Donna,
    Yes you can add more memory to this printer. It slots into the formatter (under left side cover)
    Memory upgrades
    1 MByte—C3130A
    2 MByte—C3131A
    4 MByte—C3132A
    8 MByte—C3133A
    16 MByte—C3146A
    Add up to 32 MBytes of memory to the HP LaserJet 5MP/6MP printers, for a total of 35 MBytes..
    Dec 30, 2007 | HP LaserJet 6mp Printer
    HP LaserJet 2840 Printer Logo
    272 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
