Question about Dell E771MM 17" CRT Monitor
MY COMPUTER DOESN,T RECOGNISE MY MONITOR SEPARATELY
I HAVE BEEN TOLD IT IS MY GRAPHICS DRIVER BUT I DONT KNOW WHICH MY GRAPHICS DRIVER IS
  • liangongkid2 Mar 06, 2009
    Thanks to 357reaper and dj grey for their solutions
    regards liangongkid2
  • 75 Answers
Hi,your problem is not a video driver issue,you need a driver for the monitor.you can go to manufacterer website and get a driver.
Posted on Mar 04, 2009
    Scholar:
  • 56 Answers
MMMmmmmm, no. The graphics driver won't have anything to do with recognizing the monitor. I'm assuming this is some flavor of Windows? Window will accept a "driver" for the monitor, which really is just an information (inf) file that tells windows what the monitor is capable of, so it won't try to make the monitor display something it should not, and cannot.
Get the driver from the Dell site, or this address has an executable they claim is the driver for your monitor.
http://members.driverguide.com/driver/detail.php?driverid=296757
If you get the inf file:
Right click an empty area on your desktop and select properties.
Select the Settings tab.
Click advanced button.
Select Monitor tab.
Click Properties button.
Select the Driver tab.
Click Update Driver button.
Try the auto install. If that doesn't work, try it again and point it to the inf file you got from Dell. This should allow you to manipulate the settings on your display.
Why does monitor not turn on with computer
I know this sounds stupid but make sure the monitor is plugged in and turned on. If it is then either your monitor is bad, or your graphics card is bad, if you have access to a different monitor hook it up, if it works you know it\'s not your graphics card, if it doesn\'t then it\'s probably the graphics card
Jul 21, 2014 | Dell OptiPlex Computers & Internet
Gateway a computer desktop has power but nothing on screen the computer doesn't have a tower
1) Computer doesn't have a tower? Means it is a 'pancake style' of desktop computer. A flat model.
2) No signal on monitor screen?
Good.
At least we know the monitor is good.
Problem is monitor cable, IF separate cable; or computer.
Computer isn't sending a video signal.
No Signal, Power Saver Mode, etc.
If an older CRT type monitor, (Looks like a small TV), and monitor cable is not detachable; use a known to be working monitor, and monitor cable.
If a separate monitor cable, use a monitor cable from a working computer, for a temporary test unit.
Put it back when deemed monitor cable is the problem.
Logic at this point, would deem something is wrong with the graphics chipset.
Whether mounted directly to motherboard, (Integrated), or a separate graphics adapter card. (Graphics/Video Card)
However, computer could be dirty inside, or have a bad Power Supply.
LED's (lights) light up? Maybe fans spin?
Means nothing.
1) If ALL of the Light Emitting Diodes were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 130 Watts of power.
Just depends on what Processor it is.
Older desktop computer?
Ummm, 35 to 40 Watts.
That is why LED's can light, and maybe fans spin, but no computer.
NOT enough power to turn the Processor on.
Computer needs to be CLEAN on the inside. Inside of Power Supply too, as well as possible.
Proper method to do this procedure, post back in Comment if you need guidance.
Also remove ALL Ram Memory modules, and clean gold plated contact pins on bottom; with pencil eraser.
Reinstall. Make SURE they are seated in tight, and Lock 'ears' are locked in place.
Post in a Comment, as to the model number.
Example, DX4300-05. Should be on back of computer.
Regards,
joecoolvette
Mar 22, 2013 | Gateway Computers & Internet
I need the drivers of flatron w1943tb....
LG Flatron L1515S doesn't need a driver to be installed on Windows Computer or any other systems. If you have problem with it, then it should be your graphics driver that you would need to install.
Similarly W1943TB-PF doesn't need driver. (I am not sure which one among the two LG Flatrons you have since your question is tagged under the LG Flatron L1515S while your problem refers to LG Flatron W1943TB.
If you have other problem, let me know with more details.
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | LG Flatron L1515S 15" LCD Monitor
My screen is just showing white light. benq93gx- what could be the problem?
Check your connection at the pc and at the monitor. At worst, your graphics driver may be corrupted or your graphics card may have failed.
Try re-installing your graphics driver. If you don't know how to do this, please re-post as a separate issue.
May 05, 2010 | BenQ FP93GX 19" LCD Monitor
Will not recognise the card although I know it
you need to uninstall the device and drivers-then install new driver first then install the card and be sure it is seated properly
Mar 26, 2010 | ATI FireMV 2400, (128 MB) PCI Graphic Card
I have just reinstalled windows on my pc and the resolution isn't the same. The image is too large. I have been told I need to download something from dell so my cpu will recognise my monitor, what do I...
Since you have reinstalled your Operating system you will need to reinstall the Drivers for your Video card, sound card, Modem and other hardwares. You need to install drivers for each and every hardware in your computer. Windows has inbuilt drivers for most of the common hardwares like mouse keyboard modem etc. but for some specific hardwares like Sound card Graphic card, Network card etc. for which Windows cannot load the drivers on its own, we have to install them.
Driver is a set of program which helps your hardware to communicate with the Operating system (e.g: Windows).
For your Dell Monitor E153FP you can download the required drivers from the following site:
http://support.dell.com/support/downloads/download.aspx?releaseid=R76072&formatcnt=1&libid=0&fileid=99367
Hope this information is helpful to you.
Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya
Dec 03, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
SCREEN PROBLEM
Go to a blank spot on your desktop
Right click
go to "Properties"
click on "settings"
click on "Advanced"
go to "graphics driver"
click on "graphics properties"
click on "rotation"
Then rotate it by 180degrees. Thats all..
Aug 30, 2008 | Samsung SyncMaster 910T 19" LCD Monitor
Screen Resolution
are you sure you have connected a graphics card. If so you dont need any driver because the graphics card depending on the model has already the necessary driver included just like when you first bought your motherboard.
Now, if your're only using the onboard graphics( that is the graphics card of the motherboard itself), you have to check whether the graphics supports resolution higher than 640x800. On board graphics, as far as i know contains only the necessary that will output on your screen, it means the resolution should not go much higher. But, you still have to check.
For assurance and for the best picture you wanted to have(probably your'e playing high resoulution games), I suggest that you buy the necessary graphics card that is supported by the games. Example of such brand is inno3d series.
Jan 08, 2008 | Computers & Internet
LG flatron L1710S PC Monitor
Depends on what motherboard you are using. IF this is indeed the case, you can still put a CHEAP add-on graphics card on the motherboard and get the system up and running with minimum expenses. Most motherboards support adding an additional graphic card besides the onboard chip.
Dec 24, 2007 | Computers & Internet
Dell E771MM 17" CRT Monitor Logo
917 people viewed this question
Alun Cox
