Question about Frigidaire FEF366 Electric Kitchen Range
Glass top stove frigidaire one burnenr not working
316065301 Frigidaire glass top stove back left burner not working
aborcass
  • 2651 Answers
SOURCE: Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Posted on Mar 03, 2008
SOURCE: ceramic/glass top stove
Lift the ceramic top and look at the burnner to see if it is bad or not.
You only have to take 2 screws in the front of the ceramic top at the bottom, just open the oven door and look at the corners.
Don't forget to unplug the stove first
Posted on May 10, 2008
ngfam1
  • 639 Answers
SOURCE: I have a frigidaire crown
Hi to thepanthers,
Happy to help you!
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
  • 172 Answers
SOURCE: get F5 error code. Burners
Hi jdaleq,
The f-5 code on the frigidaire ranges is a bad one. It is a ERC (electronic range control) failure. The repair manuals state to replace the control when the f-5 code shows up. You can also try to reset the control. To do this flip the breaker to kill the power, wait about 20 minutes then turn the power back on. If the problem returns then you will need a new ERC. The part number is.
#316418704 The price is $194.99 including shipping in the US. I do have these available to ship today. I hope this helps and please rate me when you can.
Mike
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
How do I fix my left rear burner that has stopped working?
First of all, you need to test the wiring to that burner. If there is no electricity, then you need to replace the plug in. You can get them at an Appliance parts store. If there is electricity, then all you need to do is get a new burner at Lowes or Home Depot. Sometimes the burner gets a tiny crack in the burner that breaks the continuity.
Sep 01, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
How do I access the burners on my Frigidaire fes367dcb glass top stove?
Sorry to read about your problem, I hope this helps you out.
you have to pull out the unit and remove the back of unit...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | Frigidaire Cooktops
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
The right front burner on my Mom's Frigidaire FEF316(I think, the # is 316232636) does not work. She heard a pop and saw a flash under the stove top near that burner when she turned it on. I switched the...
The recepticle that the burner ends plug into get worn and loose. This will cause arching and that may be what she saw. OR, there could be a wire loose under the stove top feeding the burner. Lift it up and give it a good inspection (with the breaker off). You may need to replace the burner recepticle.
Aug 01, 2009 | Frigidaire FEF316 Electric Kitchen Range
My front left burner on elec.range model FEFL67GCA does not work.
If it's just quit all of a sudden then I assume it's burned out.You will have to remove the glass top to get to it. The new burner has two wire connectors that plug in. CAUTION: Make sure you disconnect electrcal power to the stove before working on this!
Apr 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FEF366 Electric Kitchen Range Logo
734 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
