Question about HP LaserJet CM1017 MFP All-In-One Color Printer
Magenta not printing
I have serviced this printer (general clean up etc) and cleaned the contacts around the toner units.
I have checked that the magenta drum is turning ok.
Stopped the printer half way through a print, but saw NO image on the magenta drum.
I guess there is no voltage being put on the drum ?
Need to go back on site tomorrow AM with a solution...
No presure !
Any help would be grateful.
Regards
Vince.
  • 12 more comments
  • Vince Coombs
    Vince Coombs Mar 04, 2009
    I will try the "unplug and leave" route but it does not fill me with confidence ! (unless you have done this many times and IT WORKS)
    You talked about a fuse ? what or how does that make the magenta toner not work?
    Regards
    Vince
  • Vince Coombs
    Sorry... forgot to mention that the customer has replaced the magenta toner, twice.
    There is no error messsage/code, just a lack for magenta toner on the test pages.
    Regards
    Vince
  • Vince Coombs
    As I have said above, the customer has replaced the toner units twice, and as you know, the drum and toner are in one unit.
    So there is nothing wrong with the cartridge, it must be the contacts or a power board (if there is seperate feeds to each image unit, as the other 3x colour are fine.
    Regards
    Vince
  • Vince Coombs
    You asked if I had reset the fuses for the drum and image belt?
    No I have not as I don't know how to do this and unless there is a fuse for each colour on the printer I can not see how this will help.
    The other colours and the belt are working fine, just the magenta is not prining.
    Regards
    Vince
  • Vince Coombs
    "It is very possible that your ink cartridge or toner may be plugged up.
    You may also want to try and reset the system which is usually recommended after service.
    The toner unit has been changed twice (it not an inkjet machine as you know)
    This machine is not one I have worked on before, so I must ask you how to "reset" the machine as you recommend after a service?
    Regards
    Vince
  • Vince Coombs
    "I believe it is a toner problem. Do you have another magenta toner? I doubt a printer problem.
    Wow... I will ask them to change it for a third time and then run !!
    They are using genuine units and they have the same problems? I think not, but I will try along with turning the machine off for 30 mins.
    (I may turn it off and leave it at this rate, running out of time 18:45 here in UK need to leave the office and get a life)
    Regards
    Vince
  • Vince Coombs
    http://h20000.www2.hp.com/bizsupport/Tec...
    I am not sure what a USB problem has to do with the magenta not printing from a HP test print?
    The machine is on a network? no computer in sight!
    Regards
    Vince
  • Vince Coombs
    "Remove the magenta toner and drum unit and check all the contact points make sure there is no obstruction and that all the contact points are clean. "
    As I said I have serviced the printer and clean the contacts around the toner unit?
    I know this is a tuff problem as I would not have posted on this "last hope" forum.
    I just hope I find an engineer who has had this problem.
    Regards
    Vince
  • Vince Coombs
    What !
    I think you have crossed posts or way too much coffee !
    findmeifucan
    Rank: Wiz
    Rating: 80%, 128 votes
    The piston that pumps against the rubber bulb (bottom of cartridge) has jammed or is broken thus the positive pressure required to pump ink into the cartridge is not there.
    2. There's a hole, or some other leak that is allowing air into the CIS loop between the cartridge entrance port and the actual printhead, which is again stopping ink replacing that already used and grabbing air (which is obviously easier to grab) instead.
    3. There's a clog in the port that the cartridge slides into... It'd be difficult to tell if this is the issue but one give away is a whining sound that repeats again and again (this is the sound of the pump trying to pump ink to the printer)... You'd also notice a lot of ink in/around the port too as it's probably forcing some out of the cartridge
  • Vince Coombs
    Vince Coombs Mar 05, 2009
    "its a very common problem but very hard to understand many a times.i have had such a problem with one of my clients printer.we tried all posible things but it didnot work.finally we found out that everything in printer and cartridge was okay.just a small problem the earthing power spring inside the cartridge drum that powers up the drum was broken.the drums upper surface looked great but on the sides of the drum if you remove the drum out of toner by dissassembling it.u will find a hole on the side of drum from the place it gets fitted.there is a small spring or metal connecter u can say inside it that powers up the drum ,was lossened up and was not connecting as it should be.so the solution is to just replace the drum not the whole cartridge.it will definately get solved and the printer will start printing magenta again once the new drum is installed .thanks and rate the solution accordingly."
    This is what I said at the very start of my post, that one of the connectors to the toner cartridge is faulty.... BUT
    as I have said before, they have changed the toner/drum unit twice, therefore your solution makes sence but unlikely to have two faulty cartridges.
    Regards
    Vince
  • Vince Coombs
    "Try to check the unit that you have already clean maybe there is a contact that is moved or misalign, also try to check the springs and the contact point that engaging the cartridge and the drum unit. "
    I will look at the two toner cartridges (no way will they both have the same fault) but i think I will concentrate on the contacts to the drum/toner unit.
    Regards
    Vince
  • Vince Coombs
    "hi im josh in cebu phils. Friend try my solutions for your problem surely it will help you.
    Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document?and not always a contiguous half! You can do one of several things to rectify the problem:
    * Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
    * Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
    * Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
    Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge. just try this stuff.good luck"
    God this is hard work !!!
    Not the bloody ink cartridge ! It does not have one...
    and yes I have change the toner unit twice ...still
    does anyone read my problem fully ??
    Sorry need some coffee to calm down...
    Regards
    Vince
  • Vince Coombs
    Also, it is not lack of memory, etc ****, I am using a internal test page !!
    Come on.. need some professional help.
    Regards
    Vince
  • Vince Coombs
    ** UPDATE **
    I have been onsite for 2hrs looking at this printer.
    Conclusion is the toner units are ok and the problem is with either :
    1) main board faulty (power feed to the Dev units faulty)
    2) laser unit faulty (magenta laser unit stuck/faulty)
    I run a test on the magenta toner/drum unit by putting some tape over the Bios feed to the unit and running a calibration setup. A magenta toner back ground with put on the Image belt, thus proving the unit is capable to providing an image if it was told to (if the laser unit worked?)
    Any further help is welcome.
    Regards
    Vince
  • 530 Answers
Hi im josh in cebu phils. Friend try my solutions for your problem surely it will help you.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
Posted on Mar 05, 2009
  • Joseph Baculan
    Joseph Baculan Apr 01, 2009
    I guess your mainboard is already faulty you need to secure new unit.
  • Joseph Baculan
  • 37 Answers
  • 583 Answers
Its a very common problem but very hard to understand many a times.i have had such a problem with one of my clients printer.we tried all posible things but it didnot work.finally we found out that everything in printer and cartridge was okay.just a small problem the earthing power spring inside the cartridge drum that powers up the drum was broken.the drums upper surface looked great but on the sides of the drum if you remove the drum out of toner by dissassembling it.u will find a hole on the side of drum from the place it gets fitted.there is a small spring or metal connecter u can say inside it that powers up the drum ,was lossened up and was not connecting as it should be.so the solution is to just replace the drum not the whole cartridge.it will definately get solved and the printer will start printing magenta again once the new drum is installed .thanks and rate the solution accordingly.
Posted on Mar 04, 2009
  • 916 Answers
  • 547 Answers
  • albert getty
    albert getty Mar 04, 2009
    please go to this link sounds like a usb problem thanks again please take the time to rate me
    Sergeant:
    Champion:
  • 224 Answers
  • 11,896 Answers
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Mar 05, 2009
    Download Hewlett Packard - Color LaserJet CM1017 MFP Service Manualhttp://www.nodevice.in/manual/newmans/hp/emr_na-c00742624-1%5B1%5Dpdf/get30172.html
  • Nate Stansfield
    Nate Stansfield Mar 12, 2009
    I would agree. If everything checked out ok, then system board or laser components are faulty.
  • Nate Stansfield
    Nate Stansfield Mar 31, 2009
    I would use a tester and see where your power stops. If you are not getting power to the drum, I would test the board's circuits and see which component is not getting the power and replace it unless there is a bad linkable fuse or wire or loose solder joints.
  • Nate Stansfield
    Nate Stansfield Apr 01, 2009
    did you try my suggestion? what type of outcome did you get?
  • Nate Stansfield
    Nate Stansfield Apr 09, 2009
    I would dissesemble, clean, lithium grease and reassemble laser unit to see if you get a different outcome. Also check resistance and power output of wires leading to laser unit and motor.
    Sergeant:
  • 239 Answers
I think your going to have to replace the drum. as you are getting no image on it might not be the only problem but might be the only way to narrow thing down. hope things work out for you.
please rate well
  • HP Master
  • 19,396 Answers
Try first replacing the magent atoner, just in case.
If there is no power to magenta drum, then check the high voltage board that is powering the drum
  • Ginko
    Ginko Mar 04, 2009
    The strange thing is that if one of the drums is defective, or surely if irt is getting no power, you should get the error code for the printer.
    Check also the settings through control board, eventually do a reset to default.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Check the fuse is proper in printer
  • SAM ANDERSON Mar 04, 2009
    The fuse would be close to where the power cord go's into the printer.
    In previous post i meant to say did you reset fuses for the drums and belt.
    1. The piston that pumps against the rubber bulb (bottom of cartridge) has
    cartridge
    Source:edugeek.net
Why is magenta blotching on left side of printed page?
IT SOUNDS LIKE THE MAGENTA IMAGINE UNIT YOU MIGHT HAVE GOTTEN A BAD ONE.
Nov 05, 2015 | Samsung C460FW Multifunction Printer...
Prints with magenta wide lines
Your magenta imaging unit life finish,need must be change the imaging unit.
Feb 28, 2013 | Canon LBP5960 A3 Colour Laser & Free Toner...
How to clean the magenta toner out of the drum unit
Change the magenta image unit,your image unit life end,
Feb 28, 2013 | Canon Color ImageRunner LBP5970 Laser...
Magenta toner brother MFC9450C everywhere in printer
Take out the magenta cartridge and clean the nozzels and contact and reinsert it. if the issue persists get a new genuine brother magenta cartridge
Apr 20, 2012 | Brother MFC-9840CDW Laser Printer
Magenta toner is full but not printing pink
remove the toner and clean it and also check in the print option gray is not selected
Jun 15, 2010 | Ricoh Aficio SP C410DN Laser Printer
Horz. streak approx.3/4 down on each page I print
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Dec 09, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Sep 06, 2008 | Xerox Phaser 7300DN Laser Printer
Blotches of black on both sides of paper
The black slodges are most likely to be caused by the dev unit dropping black toner. Swap the black devs around and vaccum any loose toner out of the machine. The problem with the other one it that the magenta toner pump could have a fault. I would try this before cleaning the toner tubes.
Thanks Jason
Aug 08, 2008 | Ricoh Aficio AP3800C Laser Printer
HP LaserJet CM1017 MFP All-In-One Color Printer Logo
67 people viewed this question
Ben Johnson
