Question about Vacuums
Bissell ProHeat 2X Select Upright Deep Cleaner not pumping water to floor. Water is not flowing out of the pouch area into the carpet. Water does not come out of the blater, I have checked the line & valve and they are clear how do I check the pump
  • lasures Mar 10, 2009
    The vacuum motor works. I have checked the lines & the vavle in the tank and they are clear up to the plastic t. I am thinking the elictric control valve or motor is not working but i am not sure what to or how to test.
    Scholar:
  • 60 Answers
Make sure you have soap in the soap container or the water will not pump. Sounds strange I know. Even if you have the soap mixture selector turned off, it seems that these machines won't pump clear water unless the soap resovior has fluid in it. Don't know why. Hope I was able to FixYa, if so, please remember to rate my answer. Thanks.
Posted on Mar 10, 2009
    Novelist:
  • 110 Answers
Hi my name is brian. i had the same problem with my hoover upright and my line was clogged i cleaned it out and now it works fine. you might check out bissell's website and contact them for more help. they do offer parts and accs that you can purchase direct from them.
www.bissell.com
good luck and hope this helps you out
Posted on Mar 04, 2009
    Genius:
  • 1,550 Answers
Can you hear the working of Motor
  • SAM ANDERSON Mar 10, 2009
    To test motor
    First test the motor's brushes with a continuity tester or multitester.
    Turn the motor shaft or beater bar by hand. The motor should maintain continuity.
    If not, replace the brushes or take the vacuum to an
    appliance-repair shop to have it done.
    If you still have problem it is defective motor you need to replace it but cost of a new
    motor is a major investment.
    You can go with new one ,
  • Vacuums Master
  • 19,396 Answers
Check that the lines are not interrupted, probably it is a faulty water pump.
  • Ginko
    Ginko Mar 04, 2009
    To check the pump you need to disassembe the unit and test the pump by energizing, this is a risky test , and should be done by a technician, as there is AC power running in your appliance.
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Bissell ProHeat 2X Select Upright
May have a problem with the cap and valve at the bottom of the tank. Could even have a problem with the tank nit sitting down like it should. Could be a bad pump or a clogged line. If this still in warranty, take it to a warranty repair shop. It would have a years warranty on it.
Posted on Mar 13, 2008
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell 2x isn't letgtin water out on carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdgs
Mar 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My carpet cleaner doesnt **** up the water and cleaner it is a bissell turbo proheat 2x
heatman101
ydtyd
Sep 20, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Losing prime on the pump
heatman101
xczvc
Dec 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner will not spray the cleaning solution
heatman101
hgjdg
Jul 21, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
