Question about Magnum DeltaForce CB Radio
Where can i get channel selector for deltaforce 10 meter radio
I have a magnum deltaforce radio it works fine needing new channel selector heard you can get them from abroad is there any place in uk need one soon as poss
  • Anonymous Mar 31, 2014
    I have a magnum s3 with a loose channel selector how can I fix this
    Novelist:
  • Magnum Expert
  • 500 Answers
Cb shop temple, tx on yahoo search can see what i can find.
Posted on Dec 08, 2009
Channel selector only works going down not up
there is two common connections to the channel selector
up and down
resolder the channel sectors pins
then it will work
its a broken connection to a common pin
if its not a break on the selector to the PLL data bus then
use DE-OXITE 50 {this one no others for selectors} look on ebay for it
Oct 07, 2014 | Magnum DeltaForce CB Radio
Need wiring for roadking mic to deltaforce magnum radio
Turner
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Road King standard 4 pin wiring Gallaxy/ranger/cobra..............Magnum
I have no info on the 5 pin as i know the OmegaForce version has an addition mic plug, i figure yours might also.
Jul 29, 2011 | Magnum DeltaForce CB Radio
Hi my deltaforce is slightly off on ssb you have to be on 27554 and clarifier at 12 30 to be spot on 27555 thanks vince
Use a known good external freq counter, and do the tx alignment. that will put your meter back on showing the right freq when you are..
Jan 27, 2011 | Magnum DeltaForce CB Radio
My backlights are not working cant see channels at night .
The easy way is for you to get a meter find a good ground, where the coax enters in the back would be a good spot and locate one on your own instand of someone telling you and you miss understand and do harm upon your radio.
Apr 27, 2010 | Magnum DeltaForce CB Radio
Display bulbs gone on my magnum deltaforce
Yes! The faceplate will need to be unscrewed from the chasis to do it.
It isn't too tough to do with good eyesight, soldering skills, and a steady hand.
Apr 09, 2010 | Magnum OmegaForce S45 CB Radio
Magnum parts
email parts list needed to: saml@rflimited.com
He's a great guy and a pleasure to work with.
Mar 20, 2010 | Magnum DeltaForce CB Radio
Service manual
You may click this link for the service manual:
http://www.rigpix.com/cbfreeband/magnum_deltaforce_manual.pdf
Have a great day!
Apr 29, 2009 | Magnum DeltaForce CB Radio
Magnum s-3
Most likely cause is a weak electrolytic capacitor in the frequency synthesizer circuit or a voltage regulator that feeds power to it. As they age, these capacitors, which contain a viscous acidic electrolyte, can dry out but will function when warm, at least for a while, before they fail completely.
Sep 10, 2008 | Magnum DeltaForce CB Radio
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Lost manual
the way to change between channell number and frequency display is to press - FUCT then CALL,, slightly longer..
You will also want ur display to show as 33 = for channel 19 uk...27.781..... use the STEP button to split the freqs ..
Hope this helps.........RIZ, Telford
Nov 05, 2007 | Magnum DeltaForce CB Radio
Radio Communications Logo
95 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
