Question about LG Flatron L1919S LCD Monitor
PROBLEM WITH MY SCREEN
Hi. i have an LG FLATRON L1919S lcd monitorand whenever i try to do something (mostly when i try to play a game) the screen starts having some waves like radio signals or something........the problem is my screen or my grafic card? i don't think it's the graphic card because i play games that are much more realistic and it's ok. if there is any way to solve it please tell me.
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    try lowering the resolution of the game you are having problems with. Some older games will not play right on higher resolutions.
    New Friend:
  • 71 Answers
This may be the problem with the lower version of direct X software. user directX 10 ver and also upated activeX version. The problem mostly soved
Posted on Mar 04, 2009
Driver download
type "driver LG FLATRON L1919S" in Google, you'll get the answer...
Aug 30, 2014 | LG Flatron L1919S LCD Monitor
I cant see the red color on my lg LCD (flatron l1919s). instead there is like a blue light in the screen (all the pictures and faces are blue, and red events are black).
Failing internal components (but first before sending in for repair, check the computer graphics card is ok, as this, or the VGA cable to monitor may be suspect)
In effect what is happening is that the hardware that controls the spread of green and red pixels on the screen has failed (happens over time), this will need repair or more likely replacement
Apr 20, 2011 | LG Flatron L1919S LCD Monitor
How do I clean my flatron E2350V monitor
Any glass cleaner without Amonia, I use screen cleaner from Radio Shack, apply it to the micro fibre cloth and wipe the screen gently.
http://s807.photobucket.com/home/budm/allalbums
Jun 06, 2010 | LG Flatron L1919S LCD Monitor
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
I have upto now been using my lg Flatron L1919S monitor as a tv with a separate tuner. Today i replaced it with an lcd tv and was going to use the monitor for my computer. However when i connected it up...
It means your PC video resolution is too high for the monitor to display, you need to set your PC video to the native resolution of this monitor, 1280 x 1024 @60Hz.
Start up in sfae mode (hit f8 while booting up), select VGA support, then right click on desk top/properties to bring up display property/setting. set the new resolution , reboot.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | LG Flatron L1919S LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Mr Pateman
This is more likely an issue with you video card than your monitor, do all the monitors you have tested operate at the same resolution and refresh rate? It sounds like the LG monitor is running at a higher resolution and refresh rate which is causing addition load to be placed on your video card causing it to crash
May 07, 2017 | LG 22" FLATRON LCD Monitor
Change the contrast on my LG screen FLATRON L1919S ?
see if there is some software cd with it or see if display properties has somthing in setup
Jul 29, 2009 | LG L1920P 19" LCD Monitor
LG Flatron L1919S - Image on screen slides to the right
you can check your lg panel on connecting it to some other cpu
May 31, 2009 | LG Flatron L1919S LCD Monitor
Single vertical red line
Hello Monastirion,
Is the red line there all of the time without exception, for instance when you initially turn on your pc, is it there before the operating system boots?
If so, the monitor itself is most likely broken. I would return it to wherever you bought it, if possible.
Regards,
-Chester
Dec 27, 2007 | LG Flatron L1919S LCD Monitor
LG Flatron L1919S LCD Monitor Logo
194 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
