Question about Peg Perego Vespa Scooter
Vespa et2 clock
The clock on my wifes et2 dose'nt work is there a fuse or any thing and if so where would i find it?
    Problem Solver:
  • 16 Answers
There is only 1 fuse on an et2 and if the horn, starter and indicators work, then this iis not the problem.
It is most likely the battery which is at the back of the speedo. to get to this you need to remove the mirrors and screws from the handlebars, split the casing, disconnect the speedo cable and all electric blocks (carefully) and turn the speedo over. there is a little round plug that needs to be removed and the battery is behind it.
I think it is a rechargable battery, so replacing it with a normal battery will only work temporarily.
Posted on Aug 23, 2009
I have an et2 vespa i put a bit of 98 ron fuelin the tank it ran for about 3 kms then konked out now it wont even start
the Vespa ET2 50 has a two-stroke engine which needs an oil mixture in the gasoline. There are 2 (two) tanks under the seat: 1 is for gasoline and the other for 2T-oil.
If you dont't fill that oil tank the engine will run dry after a couple of miles and the bearings in the motor blow up.
Then you need a complete rebuild of the engine which costs a lot.
http://www.wotmeworry.org.uk/manuals/ET2/et2manualpt1sm.pdf
Aug 04, 2014 | Vespa ET2 50 Motorcycles
How to fix a wing mirror on Vespa ET2
you need to pull up the rubber cover at the base of the mirror and tighten the nut at the right position... fix-wing-mirror-vespa-et2-wrvo0vnsxenp22qrsalmbzkb-3-0.jpg
Sep 25, 2012 | Vespa ET2 50 Motorcycles
Vespa et2 always slow
-such strange behaviour very often occurs when the rollers (& belt)in the variator case are worn, they have to be replaced by a dealer.
-they have a lifetime of only 12'500miles (20'000km)
You should change the roll bearings in the variator box not only the belt! -the complete servicekit
vespa-et2-always-slow-zn2fhcavdapcgl1ljx1qalsv-5-0.jpg vespa-et2-always-slow-zn2fhcavdapcgl1ljx1qalsv-5-5.jpg
Jun 12, 2012 | Vespa ET2 50 Motorcycles
Need a carburator kit for a 2003 vespa ET2
Ideal that you approach the Vespa spares dealership.please log on to :http://www.vespaspares.co.uk/
Nov 30, 2011 | Vespa ET2 50 Motorcycles
My Vespa ET2 will not start when it's off the kickstand. Starts fine when the bike is on the kickstand. Engine cuts out when i push the bike off of the stand.
I'm not familiar with ET2s but I had a similar problem with a Vespa 100 years ago. After hours of messing about i discovered a bolt had fallen and blocked one of the air inlets on the bottom of the frame. Was fine when i kicked it but when my bum was on the saddle it kinda 'sealed' around the tank area and starved the engine of air. As i say, i don't know about new ET2s but sounds kinda similar symptoms.
Apr 13, 2011 | Peg Perego Vespa Scooter
Vespa et2 Engine
there might be a workshop manual for it here
Free Piaggio and Vespa Motorcycle Service Manuals for download
or i have some here
vespa
Jul 06, 2017 | 1999 Volkswagen Passat
Piaggio Vespa ET2 Scooter slows down when eccelerating
-such strange behaviour occurs when the rollers in the variator case are worn, they have to be replaced by a dealer piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-5-0.jpg piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-5-2.jpg
piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-4-3.jpg
piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-4-4.jpg
Dec 10, 2009 | Peg Perego Vespa Scooter
Turn signal replacement on vespa ET2
Front bulbs are accessed through the glove compartment, remove the round caps and you can get at the bolbs from behind
For the rear bulbs you need to remove tha full indicator unit by unscrewing the screw and taking the unit out. the bulb is accessed from behind
Jun 24, 2009 | Peg Perego Vespa Scooter
Et2 Cutting out and not maintaining revs
There is an adjustment screw on the carburetor facing towards the back wheel. You have to reach down about finger length. With the engine running and the ET2 on its stand, turn the screw until the engine revs up to a level you r happy with.
Happy scooting
Jan 26, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
741 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
