Question about HP Pavilion dv6000z Notebook
Error= hp cue status root must close system
W can i fix this thingf
  • 75 Answers
Hi,you can try restoring your computer to an earlier time,with the system tools located in the start menu.
Posted on Mar 04, 2009
HP CUE-SCANNING FLOW COMPONENT MESSAGE EACH TIME I TRY TO SCAN A DOCUMENT
When you have the Error on the Screen - Dont close it
Click START - Click RUN - Type SERVICES.MSC - Click ok
You will find
HP Cue Device Discovery in the list - doubt click and click Disable
HPQSCX08 - Double click and Click Disable
The Error should Disappear. Close Solution Center and Re-open and try Scanning.
Jun 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
Hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
"hp cue root status has stopped working" problem
This computer has OS preinstalled and a Recover CD (called RESTORE) supplied by the manufacturer.Insert this (black colored CD) let it ry to boot. Be patient and when prompted remove his CD and follow the instruction as it appears on the screen........sodeep
Mar 02, 2009 | HP Pavilion dv6000z Notebook
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
I need hp cue status patch plz
please i have vista and a message hp cue status
Dec 01, 2008 | Office Equipment & Supplies
HP CUE Status Root Error
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Aug 15, 2008 | Office Equipment & Supplies
Continuous error message
delete the hp cue discovery on your add/remove programs
Jul 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Cue Status Root has encountered a problem and needs to close.
ça m'etonne plus que chez HP ils licencient un max , c est une réponse à la con et le mec y ferait mieux d"aller à la peche que de te repondre des conneries pareilles .
sous Vista.
methode rapides .
1 /Panneau de config
2 / outils administration
3/désactiver le service HPCUE
et voilà tu ne seras plus embeter parce truc de merde .
il doit avoir une autre solution pour virer définitivement ce probleme , on verra plus tard fais dejà ça et ton pc va demarrer normalement et plus vite .
Apr 15, 2008 | Office Equipment & Supplies
HP Pavilion dv6000z Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
