Question about RoadPro RPPI-2500W Inverter
Road pro 2500 watt inverter
When my truck is running I get a red fault light and no power. When the truck is not running I get power. Can you help me with this.
3 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: getting fault light, what can I do?
Check the Following:
  1. Ground from inverter to frame is intact
  2. Positive leads are intact and clean
  3. Negative leads are intact and clean.
I hope this of help to you please rate if the answer is of any help. If I can help any further will be glad to. Good Luck and have a great weekend.
Posted on Apr 04, 2010
SOURCE: I have a roadpro 2500
Have you checked the fuses ?
Posted on Jun 17, 2011
I have a auto pro 800 watt inverter that gives 220volt ac **** wont run my kellerman freezer it runs in the house on ac can you help
If your freezer need more than 800 watts to run then your 800 watt inverter will be overloaded and it will shutdown.
Mar 21, 2012 | Vector 1000w Power Inverter
Getting fault light, what can I do? road pro 1500 watt inverter
Apr 03, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
Vector 2500 watt inverter red led fault light no output. Model veco56d.
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Mar 21, 2010 | Vector 2000w Power Inverter
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
Went u turn it on the red lite comes on and wont turn green and wont work its a road pro rppi-1500w
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Jan 07, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
I have a black and decker 1.7 cu.ft refrigerator its a 115 volts and 15 amp outlet and i am trying to put it in a semi truck. I am looking at a road pro 2500 watt. Do you think this will power it? And cool...
What wattage is the fridge Youy cant compare volts and amps withy watts.
If the fridge draws 2000 watts it wiull do the job but struggle as 2500 is the peak wattage and averages out at about 2000-2200 look at the back of the fridge. Just hope its about 15-1800 for effiecient cooling without strain on power source
Jul 28, 2009 | Electronics - Others
Road pro 1500-red fault lite blinks and has no power
unfortunately, this is a projector post. all i can say is that there is an issue with the inverters. return them to the store that you bought them from and get the next size up.
Mar 29, 2009 | Christie DLP PROJECTOR, SXGA+, 14000 ANSI,...
2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Mar 03, 2009 | Inverter Vector 400-Watt Power
My vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Feb 03, 2009 | Vector VEC056 MAXX Power Inverter
RoadPro RPPI-2500W Inverter Logo
456 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
