Question about SanDisk Sansa e250 MP3 Player
Sansa My My3 player is stuck on refresh database
  • SanDisk Master
  • 13,433 Answers
Please try to reset the player.
Posted on Mar 04, 2009
  • Ekse Mar 04, 2009
    To reset your sans e250 hold down the power button 15 seconds
    to reset your Sansa. When the player is locked using the HOLD switch, described above, the player will not power on or off. All controls will be disabled. So make sure its not on hold.
  • Ekse Mar 04, 2009
    if the problem is not solved, format the player.
    First download the user manual from this page
    Try reset All
    Try Format
    if the problem is still unsolved please use the "add a comment" to contact me.
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Refresh database
Did you try reseting it?
May 25, 2008 | SanDisk Sansa e250 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
good luck
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa E200R gets stuck in refresh when I turn it on
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
