Question about GE JBP90 Electric Kitchen Range
I have a GE stove, model JBP90. When I push the start button, the oven will not come on. Now it is showing F7. Does that mean a touchpad fix?
  • GE Master
  • 3,361 Answers
F7 is a stuck touchpad usually.
If you can not unstick the pad the clock must be replaced.
Posted on Mar 04, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Control panel flashes F7
The F7 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F7 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Oct 02, 2011 | GE 30" Built-In Single Electric Wall Oven...
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
I have the F7 code on my oven. what can I do.
I am pretty sure f7 means a stuck key pad. If you can open the console there is a tech sheet in the control panel area. It will tell you for sure the code and what it means. 877-262-1479 for parts if you come up with the correct answer I beleive you have to relplace the touchpad to fix if it is the stuck key pad
May 28, 2009 | GE Profile JT910SASS Electric Single Oven
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
OVEN DOOR LIGHT SWITCH
These instructions apply to my GE Profile JBP90 but other brands and models are similar.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Jun 25, 2008 | GE JBP90 Electric Kitchen Range
Oven does mot work
F-7 on the GE is a touch pad error, all you can do is replace the whole touchpad. You can try shutting the power off at the breaker leave off for 5 min at least. turn the power back on sometimes this will get rid of it for a time.
Feb 23, 2008 | GE JGRP17 Gas Single Oven
Touchpad doesn't work, F1 code
Most likley you have a bad touchpad. Most times its a key that is stuck and there is nothing much you can do except replace the touchpad control. It is a common problem with all electronic ranges. If the range is 13 years old I would thik about replaceing it. Good luck
Jul 15, 2007 | GE JBP90 Electric Kitchen Range
GE JBP90 Electric Kitchen Range Logo
277 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
