Question about IBM ThinkPad T22 2647 Notebook
IBM T22 Thinkpad won't boot up - not even in safe mode
I have a T22 Thinkpad it won't boot up even in any of the safe mode options. It goes to the screen offering 4 choices, each one does not work. They are Safe Mode, Safe Mode with Networking, safe mode with command prompt and last known good configuration or start windows normally. Each option gives the same result. Windows couldn't start if an error in the software. Load needed DLL's for kernel.
It stops at the bootvid.dll, so I am assuming that it is the one that's corrupted.
Has anyone seen this error before?
Thanks
    Genius:
  • 1,605 Answers
Either you have a virus or a corrupted dll file.
eitherway, beside create a bootable CD or Floppy disk, and try to fix from there, thats' time a money.
the next best thing, is to reinsall the operating system.
the other option is get a new hard drive and install the operating system on that so you can preserve the data you have on the old one.
Posted on Mar 04, 2009
Ibm x41 will not boot says boot overload
Have you tried booting in Safe Mode?
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 09, 2012 | IBM ThinkPad X41 Notebook
IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Mar 07, 2008 | IBM ThinkPad T41 Notebook
T22 disk read error
Sounds like the Operating System is corrupt. I would re-format the hard drive and re-install the OS that should solve the problem. If not then the Hard drive needs to be replaced.
Jan 23, 2012 | IBM ThinkPad T22 2647 Notebook
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
T22 boot fine, runs for four or five minutes and then dies.
The "circle z" is the power indicator light. The fact that this stays on tells that this is not an overheating problem, which is common, since in that case the power and light would go off Do you all know a blast of canned air or whatever source can clean out most dust and lint accumulations that cause this problem? Just blow in where the hot air comes out. It sounds like it could be a hard drive probem, recently I have had more failures of fairly new ones. You might try booting it in safe mode, hit (F8) while starting to boot, and see if you have the same trouble, this would eliminate a driver problem as the source if it didn't happen in safe mode
Feb 26, 2009 | IBM ThinkPad T22 2647 Notebook
How can I boot from USB in a Thinkpad T22?
I assume with "boot menu" you mean the BIOS boot menu (the one you get to if you press F12 during start up, before the Windows screen appears.)
  1. Go to "Enter Setup"
  2. Go to "Config", click "Enter"
  3. Go down to "USB", click "Enter"
  4. Make sure that "USB Bios Support" is enabled.
  5. (Hit "Enter" again and choose between "enabled" and "disabled")
  6. Hit "Esc" twice to go back to the main page.
  7. Go down to "Startup", click "Enter"
  8. Choose "Boot"
  9. Check if "USB CD" is in the list of boot options or excluded form booting.
  10. Hit F10, confirm any changes you made (click "Enter" for 'yes') and reboot.
  11. Tap or hold down F12 again and you should see the boot option menu again.
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is possible that the T22 BIOS does not support external booting. Check you version - the latest release from IBM is version 16ET32WW (1.12), release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
Jan 30, 2009 | IBM ThinkPad T22 2647 Notebook
STUCK ON STANDBY MODE
Ok, I want this off my screen. If it is stuck in standby mode as you say, press and hold the power button until the computer goes "dead." Then turn it back on. If this doesn't work, unplug it and take the battery out for a while.
Nov 22, 2008 | IBM ThinkPad T22 2647 Notebook
IBM Think pad T22 problem
Hi
Check your laptop CPU fan is running if no replace it. Problem is because of over heating....
Thanks
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
Ibm thinkpad T22 keyboard defaults
Go through the setup menu and set the numlock option to off. You will need to hit F1if I remember correctly to get to the setup.
Dan
Mar 20, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
314 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
