Question about Lenovo 3000 N100 CoreDT2080 VB PC Notebook
How can i enable intel automatic brightness - Lenovo 3000 N100 CoreDT2080 VB PC Notebook
  • Art Ellison
    Art Ellison May 11, 2010
    I am not sure just what you need. Is your screen too dim? If so, hold down the Fn key and then press the key with the little symbol that looks like the sun (on one of the special function keys at the top of your keyboard).
    Does the display get brighter when the power cord is plugged in? This is how it's supposed to be--to save battery life.
Why does the picture on my Vizio tv (model E241-A1) gets bright then darkens?
Check to see if you have a daylight savings option in your TV's settings. It will adjust the screen automatically according to the light changes in your home if it is enabled.
Sep 14, 2014 | Vizio Televison & Video
Lenovo G480 cant adjust screen brightness! please help
On AC or Battery? As I'm sure you know, your Laptop will dim the Display on Battery to save power. In Windows 7, Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, set Display time, set Sleep and Hibernate to Never, select Change Advanced Power settings, scroll through each one by one and adjust. OR right click a open spot on the Desktop, select Personalize, left bottom select Display. adjust to your preference.
Apr 16, 2013 | Lenovo G480 218422U Dark Brown 3rd...
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Dear Sir, I am having dell vostro 1510, from the past few days when i put on my ac adopter the battery indicator lights gets on but suddenly after 3-5 sec it get off again.I am not able to charge my...
You either have a faulty a/c connection and need to buy a new one at any common electronics store, or your battery cannot hold a charge.
Factors affecting battery:
Mar 29, 2011 | Dell Vostro 1510 Laptop
Internet lan drivers
Open the link provided by Intel;
Automatically detect and update drivers and software
Allow Intel to check you're system for needed drivers and updates.
Enter you're bios and make sure you're LAN is set to [Enabled]
Good luck.
Mike
May 19, 2010 | Intel Motherboard, 945GC Express, Core 2...
Intel Turbo Memory Readyboost keeps reverting back to "disabled"
Hi, sometimes when changing, or upgrading Programs or Software (Systems Configuration) will set to a (Default) service state automatically. To be certain that the changes to the (Applications) take place; be sure to make the change correctly by doing the following. 1. Enable Ready Boost. 2. Remember to always, click Apply! 3. Click (OK) 4. Restart your computer; this will help to identify, and configure the changes made to the system, on your computer. Thanks paul7of9
Jan 06, 2010 | Computers & Internet
Screen flickering
Not sure if this is your issue, but when the brightness is on full with AC plugged in, the ambient light sensor isn't as sensitive. Unplugged, it is. The ambient light sensor judges the light in the room and responses by automatically adjusting the brightness. What you could be seeing is your shift in movement blocks/allows more light to the sensor (the camera at teh top) and thus adjusting your brightness. To disable system preferences> display> uncheck "automatically adjust brightness.
Also, it may be the LCD, If you are in warranty, bring it to your local Apple store for repair.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Wireless connection on qosmio G25-513 not working
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically
then enable in your intel pro ipaddress properties auto get ip addrese.
thats it.
Nov 13, 2008 | Toshiba Qosmio G25-AV513 Notebook
Dma
DMA is Direct Memory Access : http://en.wikipedia.org/wiki/Direct_memory_access
It should be automatically enabled, but if it is not there will be no damage. DMA simply speeds up access.
Dec 22, 2007 | Intel D101GGC Motherboard
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
735 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
