Details:hp pavilion dv 2601tx problem 1: get overheated and shutdown.so,is this bcz not working fan properly? or some other reason? problem 2: laptop priviously have vista.but later i have remove it and installed xp2 . then after 6 to 7 months it was get hanged and restarted. After some days it can not start . I was tring to install xp from my cd.Then there is message that no hard disk drive is installed to your computer .What i do for it ? Is it neccessary to load vista again ? Is it possible to dual boot for this laptop? or neccessary to give it to service centre ?
  • 75 Answers
Hi I will try to help you
your overheat problem may be dirt and dust inside,or the fan may have quit.you should feel air moving out through the back.as far as it saying no hard disk,your harddrive is bad,or your motherboard isnt recognizing it.installing windows wont help.there has to be a drive present to install to.
I would check on the warranty.if it dosnt have warranty and you have some knowledge of the working components.you could take your laptop apart and clean it.the dust can stop airflow causing overheat.overheating may be causing your hardrive not to show up.have seen that before.cleaned it and it worked.no guarentee though.
hope this helps, 357reaper.
Posted on Mar 04, 2009
2 Suggested Answers
jell587
  • 447 Answers
SOURCE: get restarted again and again laptop
Problem 1: Loss of either the power supply fan or the CPU fan can create that problem.
Problem 2: Windows XP may not have the SATA driver on the setup disc for your machine thus the install doesn't "see" a drive. There is additional info at this link (at the HP website) about how you can integrate the drivers into your XP install.
You shouldn't need to load Vista again but most likely you could use a dual boot for your machine if you wanted to. For the fan issue you may want to place it into service if you aren't comfortable taking apart a laptop for checking or replacing a fan. Generally the parts can be sourced online for your machine (and usually cheaper than through a service facility) but it comes down to comfortability with the replacement procedure when deciding to put it into service.
Auto shutdown
I think you have to check if the machine is overheating. It could be the fan is not running properly or not running at all thats why the machine is shutting down. Also it could be the memory or hard drive thats causing the problem.
Feb 22, 2011 | HP Pavilion DV6700T Notebook PC
My laptop keeps shutting off it is a hp pavillion dv6000
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 16, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion dv4 Notebook drops its FPS drastically when hot
Hello,if this is the first time that happens its OK but if every time you play or you stressed the CPU shutdowns or restarts the you should take it to a repair shop.You can download a program to monitor the temperatures to see if its a CPU or graphic cards overheating.As i can see your graphic card is low-mid range and on-board so don't stress it, putting high resolutions or high details and make it overheating and stress more your CPU.
Jan 31, 2010 | HP NB199UA Pavilion Notebook
Hp pavilion dv4-1220us overheating then shutsdown
Sounds like you need to take it in for repairs, clean outs and/or replacements.
This product is known for it's heating issue and power consumption. Maybe the fan is starting to wear out and it's affecting the rest of the system. I would suggest checking the warranty on the system, if it is no longer valid, then I would look for a local tech in the newspaper.
Dec 15, 2009 | HP NB199UA Pavilion Notebook
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
Motherboard Product no. needed
HP uses a proprietary motherboard. The only way you'll find the specifics is on your build sheet from HP or by contacting their tech/customer support department. Sorry I can't be of further help. Good luck.
May 04, 2009 | ECS PN2-SLI2+ (V1.0) Motherboard
Get restarted again and again laptop
Mar 04, 2009 | HP Computers & Internet
Pavilion DV 9005 issue
Please Reviewe all connections care fully. Its Very sensitive issue. If you do not find any open connection. Once again fit the fan with all connections. No display is nothing with Display do not touch that area. See only cooling Fan.
Best Regards
Rafique
Mar 15, 2008 | HP Pavilion dv9005us Notebook
HP Pavilion zd8000 unexpected Shutdowns
Hi, There might be 3 possibilities why your laptop is shutting down: 1. You have a shortcut key in your keyboard that is pressed (accidentally or reacting to other keystrokes) that is configured to shut down your laptop; 2. You have a virus that is programmed to shutdown your laptop after a pre-determined amount of time; and/or 3. Your battery and/or AC adapter is no longer capable of supplying the power needs of your laptop. A few things you can do: a. Verify/Check if you have enabled any key stroke shortcuts for a quick shutdown; b. Check your Control Panel, Power Options, Advance tab, for any autoshutdown features, disable; c. use a known good/updated anti virus program and scan your drives. It might also be a good idea to run a program similar to Ad-Aware to scan for malicious ads; d. Charge your battery overnight and see if the problem persists. Or run the laptop with the AC adapter always plugged in to the mains and to your HP Pavilion ZD8000. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 01, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
