Question about Garden
Non starter when pulling to start to much compression can not pull it ,
  • 2692 Answers
SOURCE: when I pull the recoil rope it seems to have lost compression
Have you checked the compression? A lot of  two stroke cycle engines are running less lube due to emission which results in far more wear. Sometimes people don't realize that oil has to bve added to the gasoline.thus wearing the engine to the no compression state.
Posted on Dec 25, 2008
steve_lima
  • 181 Answers
SOURCE: Huxqvarna chainsaw Model 41
this unit does not have a compression release.you must have another problem some where.let me know what you have either done or not done to the saw and i will be glad to help......
Posted on Mar 23, 2009
slohry
  • 87 Answers
SOURCE: No start; recoil starter hard to pull.
No. Sounds like the crankcase is filled with fuel.
Posted on Apr 10, 2009
  • 143 Answers
SOURCE: 98 malibu,cranks no start,good fuel pressure,good
may be flooded. hold down gas pedal all the way and crank the engine, after a short time the engine will start to splutter and sound like it will fire. ease the gas pedal off slowly, while cranking, enough to get the engine started it may take a couple of goes. it may blow grey smoke when you get it going this will be raw fuel. holding the gas pedal down all the way, the engine will go into CLEAR FLOOD MODE and the injectors will not deliver any more fuel, until you ease off the pedal. check for dribbling injectors and the shop.
Posted on Oct 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Can't pull the starter cord,
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
Posted on May 15, 2011
Testimonial: "TRIED SOULTION BUT THAT DIDN'T HELP."
Lost my manual. Forgot how to start the darn thing?
Might it be beneficial to include a model number where the answerer cannot see the item in question? The embedded numbers (heading) are often someone elses best guess.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 24, 2010 | Homelite ZR10926 16 Chain Saw
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
M842 chainsaw wont start when hot
I suspect your warm start procedure is the fault, the manual is not correct IMO. Any choke on a warm engine causes flooding, try this, if no better post back or return it for warranty replacement.
Start Procedure
Cold:
Warm:
Lou
Mar 13, 2010 | McCulloch Garden
Husky 254 xp spark from plug but will not start plug seems to be wet
If the plug is wet the saw is flooded. Try the following to clear that condition.
Extreme Flooding by Dolfoff; Please follow this link,
http://www.fixya.com/support/t3226410
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button.
Once the flooding condition is cleared this start procedure works for every saw I have (7). Please read line 3 twice; both cold and warm.
Start Procedure
Cold:
Warm:
Good Luck. HTH
Lou
Feb 27, 2010 | Husqvarna Garden
Could I please have the basic start procudure for the poulan 2375 Borrowed from a friend. won't completely turn over
1) Have fuel tank full of a mixture of 50:1 gasoline and 2 cylce oil.
2) Have bar chain oil tank full.
3) Push down choke to full
4) Pull over engine 2 times.
5) Push choke off
6) Pull over engine. If it does not start you may have flooded engine ect.
Please let me know.
Feb 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
It starts and runs but when you turn it off it won't restart.
I think the warm start procedure in the manual is causing it to flood. Try it like this, if you continue having problems reply below and we will try something else. PLEASE read #3 (Cold and Warm) a few times before attempting to start. Try it without 1/2 choke (your manual); completely open.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed or at 1/2 choke position.
Hope this helps.
Lou
Feb 21, 2010 | Poulan Garden
The engine is flooding while trying to start
Clean the air filter and spark arrestor (muffler)
Drain and refill the feul tank with mix less then 1.5 months old.
Start Procedure
Cold:
Warm:
If it still does not start reply (with what you have done and we will continue. HTH
Lou
Feb 06, 2010 | Garden
Cylander keeps filling with gas when trying to start
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
OPEN THE CHOKE
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and LISTEN for an attempt to start. once heard (usually two pulls)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
Hope this helps
Lou
Oct 28, 2009 | Garden
Chainsaw won't start
Check for spark
Ignition Coil Test
Smalleng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If spark present put a small amount of mix in the carburetor. Does it at least try to start?
If yes you most likely have a fuel delivery problem.
If no any number of problems. Try your friendly neighborhood chainsaw shop.
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Warm:
Hope this helps
Lou
Oct 04, 2009 | Husqvarna Garden
Will not start
I
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
These flood easily and are very difficult to start once that has occurred.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle - Don’t pull with choke closed.
Hope this helps
Lou
Sep 28, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
