Question about Dell Inspiron 1501 Notebook
Dell inspiron E1505 cannot connect to internet
This is the info on computer, I put Ping and the ip address on command prompt and it says hardware error......I have the cable connected to the broadband modem...I have windows xp media center edition. this is the error I get keep getting this error message on my Dell inspirion E1505 LAPTOP
Limited or no connectivity. You might not be able to access the Internet or some network resources. This problem occurred because the network did not assign a network address to the computer.
When I try to repair it says : Windows could not finish repairing the problem because the following action cannot be completed: Renewing your IP address.
I also get cannot find server on DNS error
I have a another computer connected to the internet, so it is not the internet or modem, it has to do with with the laptop, It worked fine just a couple days ago it completely stop working when the power went out, it also keeps freezing.
Host name....... : CLAUDIA
Primary Dns Suffix......: (blank)
Node type ........:HYBRID
IP Routing Enabled......:No
WINS Proxy Enabled.....: No
Ethernet adapter wireless network connection Ethernet adapter Local Area Connection:
Connection - specific DNS Suffix.... : (blank)
Descripition.........: broadcom 440x 10/100 intergrated contoller
Physical Address ........: 00-15-CS-11-33-10
Dhcp Enabled....... : Yes
Autoconfiguration Enabled ......: Yes
Autoconfiguration IP Address.....: 169.254.35.189
Subnet Mask........ : 255.255.0.0
Default Gateway ...... : (blank)
  • 9 more comments
  • cnc74 Mar 04, 2009
    no solution just adding to problem:
    now under network connection details it says ip address as 192.168.1.100 under lan or high speed internet is says local area connection connected but I can't get the internet, it says page can not be displayed....Thank you
    Sorry, I know now why I gave two isp above, I have two routers one is the modem from the cable company and that works fine, the other is linksys 4 port router so the ip on the linksys is tge 192.168.1.100 and the statistics came back as packets sent 4 received 4 lost 0
    there is a section that says ethernet adapter wireless netowrk connection media state =media disconnected
    yes, I have 2 and I get the same problems. I also have two modems, I know for sure the one from the cable company works, and that is the one I am using now on this computer, I connected both cables to that modem and the laptop still not working. In safe mode it does not allow me to connect to internet either, I had no problems last week it happened saturday and now nothing....
    I have another ethernet cable, I just tried that one also, and I still get the page cannot be displayed..
    okay let me try, no it is not wireless modem. it is a linksys cable/dsl 4 port router....My laptop has a wireless card on there, but there is no other wireless connection in the neighborhood that it will pick up. The other is a cable modem from TWC. they both say internet and the light is blinking green....... Firewall is off, the only thing I have is adaware, no mcafee.....I went to windows firewall and it shows network connection settings 1394 connection and it is checked.
    local area connection and it is checked
    and wireless network connection and it is all checked....when i select setting in that screen there is nothing checked in the list of services, should any of these be checked?
    yes, tried all 4 ports.I checked the tcp/ip properties and in the general tab it is selected, properties it it checked obtain ip automatically the same for dns sercer it says in the ip settings dhcp enabled. does the safemode allow you to access internet or no?
    okay then it is still not working, the internet... on top of that when I do get in my desktop it freezes, so I have to go to safemode with ntwrking to try to fix it. not sure what it is the local area connection says connected, but somewhere there is a disconnect because it will not access the internet....frustrating...
    okay does that have to do with the wirelss only or both ? I don;t need the wireless if I the cable connection, just can;t get the internet to work. you think is there a way to check if the network port is good?
    yes, but the other is a work computer so I can't combine that to anything, or download stuff, so that is not an option.... Thank you though for trying to assist.
    no it won't, used this site many times..thnks
    Sergeant:
    Champion:
  • 224 Answers
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Posted on Mar 04, 2009
  • 4 more comments
  • Shakeel Muradali
    Shakeel Muradali Mar 04, 2009
    Wow. ok, so just to catchup the problem you are having is with the linksys right? You have connection, but no internet access. is this a wireless modem? You trying with wireless or RJ45 cable?
    Also, check the fire wall in the control panel as it might be blocking your modem connection. Do you have a firewall software like macafee or symantec? try disabling that when trying the internet. You'll need to try many solutions to narrow down and eliminate possibilities. Sorry for that
  • Shakeel Muradali
    Depending on the service names you can try checking one by one to see if it solves your problem. Ok, so a four port router. I'm assuming you've tried all four ports and they behave the same.
    Now, i would also assume you are on DHCP. Have you checked your network TCPIP settings to see if it is set to online?
  • Shakeel Muradali
    yes it does but you have to select "safe mode with networking" option.
  • Shakeel Muradali
    Dude, the only think i can think of is a bad NIC card. I think the power problem damaged your network port. Not sure if you can but you could get a PCMCIA or an Express card NIC card and try it out. I'm still thinking of anything else we could try...
  • Shakeel Muradali
    You have two computers right? You can get a twisted pair network cable and connect the two computers directly using the twisted pair network cable. You'd need to assign statis IP's to both machines and see if you can see the other PC. That way, you'll know if your network port works. other than that, Can't think of another way.
  • Shakeel Muradali
    You're welcome. I'm sorry i wasn't able to assist you. I hope this has not put you off using fixya.com. I hope you will get back to us if you have any other questions. have a nice day
Ping ip address
I think there may be a connection problem from your side or in that ip address you pining.So better reset the modem or router then ping it.
To ping ip address you can use method in windows XP.
Goto start-run-command prompt-Ping ip address
For example: Ping 55.253.12.86
You can ping ip address or website using the site Whoisxy.com
May 21, 2013 | Computers & Internet
Well i have a dell latitude d600 and i can get the wifi connection on my computer but cant connect to the internet whats going on
if u know the IP address of your router and ur servicve provider's server IP then ping it....
go to Start/Run
in the next window type this
ping 198.168.1.1 -t (the number is the IP address of ur router...replace the number written by me with ur router number)
ping 59.179.243.70 -t (the number here is the IP address of internet service provider server...replace the number written by me with one for your internet service provider server IP address)
the ping window will be a DOS window with responce from the respective server/router with milli seconds mentioned as responce time....if that comes then ur connection is ok
for further info check with ur internet provider
Feb 18, 2010 | Dell Inspiron 1501 Notebook
My Dell Inspiron 9300 Notebook computer won't get online wireless or with an ethernet cord. I have trouble shooted within the computer and the computer says there is a wireless and wired connection. When I...
you can ping a website to check if there's data flow. if you're using vista just click the Start button and type in command in the start search, then right click the Command Prompt and select "Run as Administrator". in the command prompt just type in this command:
ping www.google.com
if the result is 0% loss then there is dataflow, it might be your firewall blocking the connection or your browser itself is not working properly. you might need to reset the browser if that's the case.
if the result is 100% loss then type in this command:
ping 64.233.189.104
if the result here is 0% loss then it's probably a DNS problem which is quite easy to resolve. you can download and run this application from microsoft:
http://go.microsoft.com/?linkid=9657448
hope this helps you...
Nov 13, 2009 | Dell Inspiron 9300 Notebook
Lost connection
1. check ip address in command prompt
2. If unable to find valid ip address , reset ipaddress , in command prompt type ipconfig /release and then ipconfig /renew
3. Ping default gateway in command prompt
4. then ping www.google.com in command
5. If u can ping in command prompt issue with Internet explorer or with Operating system.
6.Try using different browser.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cannot connect although plugged in
Check the ipaddress. Type ipconfig in command prompt. Then ping a website in command prompt if u get proper ip address e.g 10.132.147.121. Try to ping www.google.com in command prompt. If u are unable to connect. Tried to release renew Ip address.
Type ipconfig /release then ipconfig /renew in command prompt. If you are able to ping google and still unable to connect to website using internet explorer, then issue with browser or with OS.
Dell Inspirion E1505 internet connection problem
Have you properly entered in all of your network's info into the laptop?  Sometimes security settings can block access to the Wireless network.  Here's a quick way to diagnose network connection.  (Make sure you know the IP address of your router!)
1. open your Command Prompt
2. type in the following "ping (Router IP address example: 192.168.1.1 " after entering the following press enter.  (you should see a series of lines that say how long the packet took to make a round trip...if not, then you have no connection to the wirless network)
3. if the results of the ping test read "100% loss" you know that connection is definately not established.
Your next course of action should be to inspect your laptop's settings and ensure that your laptop can "see" the router.  If your laptop's NIC ( Network Interface Card ) cannot detect the network it is possible that the NIC is bad or your router isn't set to "Broadcast" your SSID ( Service Set Identifier ) aka network.  this following article might be able to assit you in the troubleshooting process more throughly.  I hope this to be of some help to you!
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx#2
Feb 04, 2009 | Dell Inspiron E1505 Notebook
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Wont conect to internet
hi. sir.
go to the internet option>
connection>
setup> choose which type u need to do>
see whether the modem is enabled first. thank u. sir
Sep 03, 2008 | Dell Inspiron 1100 Notebook
Unable to connect to internet.
Go to any working computer on your network.
go to start
programs
accessories
command prompt
at the command prompt, type ping and your IP address.
2) or go to start
go to run
in the run box, typr cmd,
at the command prompt type ping and your ip address
thanks
Jul 18, 2008 | HP Pavilion dv8000t Notebook
Internet connection
Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Jun 18, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 1501 Notebook Logo
3,630 people viewed this question
Alun Cox
