Question about Directed 1100d Car Audio Amplifier
Directed 1100 d turns on but no sound
Ok ive got a directed 1100d amp when i turn my system on the amp powers up then clicks stays on but doesn't put out anything if you leave it on for a while it will start to reverberate through the sub like its trying to play but never goes any further can anyone give me an idea what is wrong or an idea how to fix it?
  • biggdaddy050 Mar 06, 2009
    well DJ X, i tried what you said the amp is grounded idividually the power is great however i am using 4 awg power and 4 awg ground should i step up to 0 awg that just seems like overkill to me
    same results tried running a new set of rca's out side of car just for test purposes and nothing changed the amp still powers on then clicks and does not put any sound. ive been looking into this problem online and it seems to be a common thing and all my other amps still work fine . i have a total of three amps and a crossover network wired in and everything else works fine its just the directed thats giving me a headache (stress not bass)
    Scholar:
  • 61 Answers
Hi there
few steps to try
1) try grounding amp to a new location
(make sure the amp is grounded by itself)
2) check the power wire from the battery to the amp
3) if the 2 steps don't solve the problem try turning your amp settings down and disconnect the power wire from the amp after a few seconds reconnect the power wire and amp should reset itself.........
if this doesn't work let me know there are other tricks that can be done but these are the most common firsts to be tested (also make sure the ground wire is larger than the power wire)
hope this helps
Posted on Mar 06, 2009
  • cory leitch
    cory leitch Mar 06, 2009
    no 4awg is good ........try turning the power off manualy on your deck by holding the source button down once your deck powers off ...shut the actual power off to your car wait a few minutes 2or3........start your car and hold source down to turn your deck back on..........let me know if your deck reset itself if not take a look at the rca wires running from deck to amp sometimes after hidding the wires in the car they can actully ground to the metal of your car overtime...........if these steps dont solve it let me know again hope this can fix it for ya
  • Nafeez Kurreembukus
    Nafeez Kurreembukus Apr 02, 2015
    hi there i have tried all the steps but still doesn't work.the amp turn on, green solid light and esp light solid red. but output.
Overload indicator light stays red & continuous tone ups 1100
Take the battery out and see if it does the same thing when you turn it on.
Feb 06, 2013 | APC Back-UPS Pro 1100 (BP1100) UPS System
Reolacement plate amp for infinity tss 1100 subwoofer
Hi my name is MIchael and I repair the following amps JBL PB10, PB12 If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR PB10 PB12 - you will find us ... Edwards Electronics ....
Apr 29, 2012 | Infinity TSS-1100 System
The green light and protection light on my 1100d constantly blink and the interior lights in my car blink in sequence with the lights on the amp and I get no sound out of the amp and sub setup. What could...
Sounds like you have an issue with the amp, the install, or possible blown subs.. check, test and if all else fails get the amp serviced or get a new amp.
A good car audio shop can also help you check it over.
Feb 06, 2011 | Directed 1100d Car Audio Amplifier
Hi, ive jus added a pioneer avh5900 in to my car.. the problem i get is when my volume reaches between 17-21 which does seem to blast my speakers, my sounds jus cuts out on the system, altho the system...
Hi does the amp go into protection mode? or does the sound dip and amp stays on? if it goes into protection mode there's a good chance your running the amp wrong. If it dips and stays on its a power problem that can be fixed by adding a farad capacitor.. thank you for using Fixya.com
Feb 09, 2010 | Pioneer AVH-P5000D Car DVD Player
Yamaha YSP 1100 clicks when press power button but does not turn.
Hi
I have the YSP1000 and I had a similar issue but it was less frequent. I located the clicking sound which turned out to be a relay on the main circuit board. Before replacing it I removed the relay cover and cleaned the contacts. It has not miss behaved since and that was some 8 months ago. Give it a wizz
Mike
Apr 13, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Amp doesnt turn on.
it sounds like it is blown..one way to test it is put the remote wire and the power wire together and put it to the possitive of a drill battery and the put the ground to the nagitive at the drill battery..if it goes right to protect then it is blown!
Mar 04, 2009 | Directed 1100d Car Audio Amplifier
My 1100d directed amp cuts n and out as i play it, and sometimes
most reputable car audio shops can give you (or have thier own) repair techs. is the new amplifier rated down to the same impedence you have your subs wired to?
Any protection lights coming on the face of the amplifier?
It has a lights that come on for Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection.
May be a faulty turn on module.
Get it repaired before more happens internally for a costlier repair.
Dec 17, 2008 | Directed 1100d Car Audio Amplifier
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
Directed 1100d 2-channel amp
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Oct 17, 2007 | Directed 1100d Car Audio Amplifier
Directed 1100d Car Audio Amplifier Logo
285 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
