Firmware updates for hp CLJ 47000dn
Where cn i download the firmware for Hp color laserjet 4700dn printer?
    Sergeant:
  • 239 Answers
You can down load and software and firmware for free from HP's website.
hope this helped
please rate well
Posted on Mar 04, 2009
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
HP Laserjet 4700dn suddenly stops printing in color although the cartriges are new and were working well. What is the problem?
>Go to menu settings, select set as default setting, do color calibration.. try for the print..> take configuration page, verify the firmware version, if low, download from hp web site, up load as specified..
Feb 01, 2012 | HP LaserJet 4700DN Printer
I keep getting a 51.20 error on my 4700DN - any ideas where i should go next?
Laser beam error, caused by the "black" laser.(each color has it's own laser). !st go to www.hp.com and upgrade the firmware. You can do that yourself. If that doesn't fix the problem or you are uncomfortable doing the upgrade, call a technician.
Aug 11, 2011 | HP LaserJet 4700 Printer
Hello HP 47000dn when you print a ppt of 8 pages appears the error 49.4c02 Service error
Most 49 errors can be fixed by updating the firmware on the printer. Your issue is very common, especially if you just updated Adobe Acrobat. Go to HP.com and search for drivers and software. As you list 2 different printers I do not know which one you have or I would link it. Once you get to the drivers page look in the cross operating system (bios firmware) section and you will find the firmware updates here. Download the appropriate one and follow the instructions in the read me file to install. Post back with proper model number if you have issues and I will provide a direct link.
May 13, 2011 | HP LaserJet 4600dn Color Printer
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
HI My HP color laserjet cm 1312nfi printer displays only ready 2 download on LCD.
you need to update your printer's firmware. please download the firmware from www.hp.com and run in when the printer is conected to the pc
Sep 22, 2010 | HP Laserjet CM 1312NFI Color Printer
Hi I have an HP CLJ CP3505 it has stopped working and is asking me for a Send RFU Upgrade? Does anyone please know what to do?
Jan 04, 2010 | HP Office Equipment & Supplies
I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Jun 22, 2009 | HP LaserJet 5550DN Printer
HP Color LaserJet 2600 Printer color shifting
this will solve the problem... check out this link
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Color LaserJet 3500 Printer
811 people viewed this question
jasbo
jasbo
